problem with Port _b_ inpeetrup
huma
PostPosted: Sat Oct 21, 2006 5:37 am     Reply with quote
hello
i have to take input from encoders for that i decided to use RB4 pin(interrup on chnage) on pic16f877. i used the example code EX_PBUTT.c with little modifications.
on change i on/off led attached to RD0 pin.To have interrupt on change i used to ground pin RB4 & RB5.
The code is working well in proteus simulation but when i use it on actual hardware it is not responding well.
Instead when i ground pin RB3 it toggles LED. I m not getting wht the problem is .
I have also read the forums regarding port B interrupt on chnage but i m getting no info.
Please help me out.
Also i am not understanding why #if LOWTOHIGH & #elif HIGHTOLOW
are used in program.
#include <16F877.h>
#define LOWTOHIGH TRUE
#define HIGHTOLOW FALSE
short int dbutton4, dbutton5, dbutton6, dbutton7;
#int_rb
void detect_rb_change() {
   int current;
   static int last=0;
   set_tris_b(0xF0);
   current=input_b();
   #if LOWTOHIGH
   if ((!bit_test(last,4))&&(bit_test(current,4))) {dbutton4=1;}
   if ((!bit_test(last,5))&&(bit_test(current,5))) {dbutton5=1;}
   if ((!bit_test(last,6))&&(bit_test(current,6))) {dbutton6=1;}
   if ((!bit_test(last,7))&&(bit_test(current,7))) {dbutton7=1;}
   #elif HIGHTOLOW
   if ((!bit_test(current,4))&&(bit_test(last,4))) {dbutton4=1;}
   if ((!bit_test(current,5))&&(bit_test(last,5))) {dbutton5=1;}
   if ((!bit_test(current,6))&&(bit_test(last,6))) {dbutton6=1;}
   if ((!bit_test(current,7))&&(bit_test(last,7))) {dbutton7=1;}
   #endif
   last=current;
void clear_delta() {
   dbutton4=0;
   dbutton5=0;
   dbutton6=0;
   dbutton7=0;
void main() {
   clear_delta();
   port_b_pullups(TRUE);
   enable_interrupts(INT_RB);
   output_low(PIN_D0);
   while (TRUE) {
      if(dbutton4) {
        output_high(PIN_D0);
        dbutton4=FALSE;
      if(dbutton5) {
        output_low(PIN_D0);
        dbutton5=FALSE;
jecottrell
PostPosted: Sat Oct 21, 2006 6:30 am     Reply with quote
I believe these are used to set whether you want to detect a switch change from low-to-high or high-to-low... If you are grounding a pullup with a switch then you would use HIGHTOLOW. To do that you would comment out the appropriate #define line.
//#define LOWTOHIGH TRUE
Good luck,
John
