Two's complement
hansw
Two's complement
PostPosted: Fri Oct 20, 2006 10:59 am     Reply with quote
What is the fastest way to do Two's complement a variable
In this case the parm name is Value
C version. I did not expect so many instructions.
The compiler does not use comf
.................... Value = (!Value) + 1;
154A0: MOVF xC0,F
154A2: BTFSC FD8.2
154A4: GOTO 154AE
154A8: MOVLW 00
154AA: GOTO 154B0
154AE: MOVLW 01
154B0: ADDLW 01
154B2: MOVWF xC0
Is the #asm version correct?
Will this assembly produce the same results ?
.................... #asm
.................... comf Value
154B4: COMF xC0,F
.................... incf Value
154B6: INCF xC0,F
.................... #endasm
Is there a faster way ?
hansw
PostPosted: Fri Oct 20, 2006 11:37 am     Reply with quote
Do this:
value = -value;
From the .LST file:
...... value = -value;
0082:  NEGF   value
PostPosted: Fri Oct 20, 2006 11:46 am     Reply with quote
Do this:
value = -value;
From the .LST file:
0082:  NEGF   value
Thanks PCM programmer....
That helps, can't get much less than that.
hansw
