16f628A and a LED Display Driver
PostPosted: Mon Oct 16, 2006 9:27 pm     Reply with quote
What are some choices for 7 segment LED display drivers? I want to hook up just one for now, and upto 4 later on. The PIC I will be using is a 16f628A
bsodmike
View user's profile Send private message Visit poster's website AIM Address MSN Messenger
PostPosted: Tue Oct 17, 2006 1:34 am     Reply with quote
Rather than using the traditional driver, which only (afaik) allows BCD digits + dp control, you can multiplex the lines by hand, and all this means is that you'll have,
  • a,b,c,d,e,f,g,dp
  • driver lines
So this allows up to (n) devices depending on how many driver lines + 8 i/o for display data. So what you need to do is 'rasterise' the display fast enough and if you keep it to >100Hz it should appear as steady text/letters Smile
//Of course the max number of digits will be limited by the speed of your MCU and if you can keep refreshing it > 100Hz.
I did something similar here,
Characters you can create (without being restricted, apart from ROM for the fonts),
http://en.wikipedia.org/wiki/Seven-segment_display
Btw, I got a load of these PCBs left, so let me know iif you'd like one or more Smile
PostPosted: Tue Oct 17, 2006 5:59 pm     Reply with quote
Yeah Id be interested in one or possiblly two.
How much are they?
