hadeelqasaimeh
| 18f458 and string |
Posted: Mon Oct 16, 2006 12:35 am |
hello all;
im working on 16f877,,i try to send and Receive serial string.
then do some function and print on lcd.and its work fine;
i try now to do same but using 18f458,,but it dont work
here is my Receiver code:
#include <18F458.h>
#include <lcd.c>
#int_rda
void serial_isr()
jj=1;
lcd_init();
enable_interrupts(INT_RDA);// turn on interrupts
jj=0;
output_low(PIN_A0);
lcd_putc('\f');
output_low(PIN_A0);
lcd_gotoxy( 1, 1);
printf(lcd_putc(" WAIT"));
if(jj==1)
output_high(PIN_A0);
output_low(PIN_A0);
lcd_putc('\f');
lcd_gotoxy( 1, 1);
printf(lcd_putc(" interrupt"));
jj=0;
my transmitter code is simpley "printf" and delay time
any body can help,plz |
Posted: Mon Oct 16, 2006 2:46 am |
First thing, your 'receive' code, is going to physically hang the UART. You are not reading the received character, and you are then delaying. Result, the UART internal buffer _will_ overflow, and the UART will then be physically hung.
Change the code in the following ways:
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS)
//This makes the compiler add code to _recover_ from the hung state...
char received;
#int_rda
void serial_isr()
jj=1;
//delay_ms(100);
//Do _not_ delay in an interrupt. There are occassions, where _short_
//delays, may be used, but delays inside interrupts, should be treated
//as if they bought the 'black death' with them...
received=getc();
//You need to read the character, or the interrupt will keep recurring.
With these changes, it should start to work, and you can then solve the rest yourself.
