EX_RS485.c compile error
morebudwiser
PostPosted: Thu Oct 12, 2006 6:54 am     Reply with quote
hi trying to complie rs485.c example program that comes with the complier (3.245) and it keeps coming back saying out of ROM a segement of is to large main 0003f
anyone know why im getting this error or how to fix it i have not change the example in any way
many thanks morebudwiser
PostPosted: Thu Oct 12, 2006 7:01 am     Reply with quote
rs485.c, is not meant to be compiled. The 'example', is ex_rs485.c (in the examples directory, not the drivers directory), which then loads this part as an include file (why CCS used .c as an extension, rather than .h for this file, I do not know). rs485.c, needs the extra definitions in the example file, before it'll compiler.
morebudwiser
Ex_rs485_chat.c
PostPosted: Fri Oct 13, 2006 3:34 am     Reply with quote
hi sorry i meant rs485_chat.c will not complie
PostPosted: Fri Oct 13, 2006 3:42 am     Reply with quote
Er. Don't know of any such example (rs485_chat.c).....
PostPosted: Fri Oct 13, 2006 4:18 am     Reply with quote
hi it is listed in the complete examples list on ccs web site as Ex_rs485 and its function is Simple messenger utilizing RS485
PostPosted: Fri Oct 13, 2006 7:28 am     Reply with quote
That is ex_rs485.c, which is included with the compiler, not 'ex_rs485chat.c', or 'rs485.c'. The version that comes with the compiler, will compile OK. The latter version (which is what you get if you download it seperately), will give problems depending on your compiler version, unless you use a chip with more ROM (16F648A).
