Problem with RC5 code
tomi7
PostPosted: Wed Jan 05, 2005 1:21 pm     Reply with quote
I have wrote program for pic12f675 to decode rc5 code.
It works, but decoding rc5 is not correct.
What is wrong ? Can You help me ?
#include <12F675.h>
#device adc=8
#use delay(clock=3579545)
#fuses NOWDT,XT, NOCPD, NOPROTECT, NOMCLR, PUT, BROWNOUT
#use rs232(baud=9600,parity=N,xmit=PIN_A0,rcv=PIN_A1,bits=8)
#define IR_SENSOR PIN_A2
#define IR (!input(IR_SENSOR)) //invert bits
int1   flag=0, bit;
int8  code, adress;
int16 i, j, tmp;
int make_8_from_16(long word, short high_low);
#int_EXT
void EXT_isr() {
   flag=1;    //IR transmit
   setup_adc(ADC_OFF);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_2);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   enable_interrupts(INT_EXT);
   ext_int_edge(H_TO_L);
   j=0;
      if(flag==1)  //half first start bit
          tmp=0;
         delay_us(400);  //second half first start bit
         for(i=0;i<14;i++)   //14 bit (start bits + addres + code)
            bit=IR;
            if (bit==1)
               tmp++;
            tmp<<=1;
            delay_us(1775);   //wait 1,776ms for next bit
         code=0;
         adress=0;
         code=make_8_from_16(tmp,0);
         code&= 0b00111111;  //only 6-bit
         tmp>>=6; //delete code bits from tmp
         adress=make_8_from_16(tmp, 0);
         adress&= 0b00011111; //only 5-bit
         if(code && adress)
            printf("a: %x ", adress);
            printf("c: %x ", code);
        flag=0;
#BYTE word0 = word
#BYTE word1 = word + 1
   if(high_low == 1)
      return(word1);
      return(word0);
jds-pic
PostPosted: Wed Jan 05, 2005 4:05 pm     Reply with quote
example of problem please?
i.e.,
what is your input?
what is the expected output?
what is the incorrect output?
jds-pic
tomi7
PostPosted: Thu Jan 06, 2005 1:30 pm     Reply with quote
I use TSOP1738 as IR receiver. Transmition rs-232 works correcly.
Decoding rc5 is wrong, if a press "1" key I get code 30h in place of 01h,
"2" - 28h
"3" - 20h
"4" - 18h
etc...
CMOS
PostPosted: Mon Oct 09, 2006 1:56 pm     Reply with quote
Have you managed to successfully decode RC5 signals? If yes can your please share your code?
