treitmey
Is rotate_right broke in V4.x |
Posted: Wed Oct 11, 2006 11:25 am |
----------edited---------
FIXED 4.012
If I put in the printf this code compiles.
But if it is removed it gives error that rotate_right expects a * pointer.
any statement will work instead of the printf,.. g=0; ect.
Could someone confirm this.
Am I missing something?
Code: | #include <16F877A.h>
#device *=16
#fuses hs,nowdt,noprotect,nolvp,put
#use rs232(baud=19200,xmit=PIN_E2,invert,stream=debug,disable_ints)
#use rs232(baud=1200,errors,xmit=PIN_C6,rcv=PIN_C7,parity=e,enable=PIN_C5,bits=8,stream=CIM)
#case
#zero_ram
void main(void){
int32 g;
//fprintf(DEBUG,"STARTING\n\r");
rotate_right(&g,4);
Mauricio Lopes
Posted: Wed Oct 11, 2006 12:17 pm |
I try to compile your code, and with or without the printf this works... There´s no erros... _________________ Best Regards,
Mauricio Lopes |
Benjamin
Joined: 11 Jan 2006 Posts: 21 Location: Quebec (Canada)
Posted: Wed Oct 11, 2006 1:01 pm |
Hello treitmey,
I tried your code with version 4.011 and I get the same result: Compiles with the printf but not without. What's also odd is that changing the rotate_right fonction by rotate_left does compile. The code works fine with version 3.249, I would suggest using this version since version 4 is not yet stable. |
treitmey
Posted: Wed Oct 11, 2006 1:12 pm |
Right, I am using the 3.249 for the production code.
Just saw this as a VERY weird V4.x error.  |
