Need help for moving data from 1 array to another
The Puma
PostPosted: Thu Oct 05, 2006 12:04 pm     Reply with quote
I have the following problem:
I have an array display_buffer[50]
This array is used to display data to ten 5x7 matrix displays
Then i have a array input_buffer[100]
This array hold the data to be displayed
Now i will move the data from array input_buffer[0] to display_buffer[0]
50 bytes width
Then i will shift the data of array input_buffer[0] to display_buffer[1]
50 bytes width
I need this for a moving text board with ten max7221's
This will rotate the text from right to left one colums each time
Please help me with some sample code to do this
Can his be do with memcopy ?
rberek
PostPosted: Thu Oct 05, 2006 3:07 pm     Reply with quote
It would be useful for you to go back to your original threads on this topic, as many of the answers have been given to you already.
Specfically, if you look at this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=27092&highlight=
you will see that circular buffers were recommended as a solution to what is the same problem you had 6 months ago. You don't physically move data, you move the pointers to the data.
Physically moving/shifting this amount of data is impractical. You can write data into your input array, then your display data can be obtained by pointing at the elements of the input data you are interested in displaying. After that data has been displayed, you may then overwrite it with new input data, or whatever. You just need a pointer to tell you where to place newly-arriving display data, and a pointer to tell you the next element or elements to display. These pointers move as data arrives or is displayed.
Before you ask, no , I have not used these display drivers to display and shift data, and no, I do not have sample code.
