		| Author | Message |
		| arunb
				| Does this .LST file indicate any problem ?? |
				|  Posted: Tue Oct 03, 2006 5:31 am |   |
				| Hi,
 I have this lst file for a PIC project (16F628) does this indicate any problem ???
 CCS PCM C Compiler, Version 3.169, 16542
 Filename: AnLogger8Chn.LST
 ROM used: 1929 (94%)
 Largest free fragment is 119
 RAM used: 77 (44%) at main() level
 90 (51%) worst case
 Stack:    5 worst case (3 in main + 2 for interrupts)
 thanks
 arunb
		| Ttelmah Guest
				|  Posted: Tue Oct 03, 2006 9:13 am |   |
				| No. However there were problems with the configuration settings for some peripherals on chips like the F628, on earlier compilers, and 3.169, might be old enough for this to apply...
		| arunb
				| RE": |
				|  Posted: Tue Oct 03, 2006 10:58 am |   |
				| Thanks for the reply.
 Actually I had no trouble with 16F628 and PCM 3.169.
 Now I am using 16F648A and PCM 3.228.
 I find that whenever 'ROM used' exceeds 'Largest free Fragment' with stack level below 7 , the PIC behaves erratically. Is this normal ?
 Could there be a problem in the programmer as well, because now I use my own ICSP based programmer , whereas I used Picstart Plus previously ?
 thanks
 arunb
		| Ttelmah Guest
				|  Posted: Tue Oct 03, 2006 2:37 pm |   |
				| No, it is not 'normal'. Check the revision numbers for the chip, there are quite a few erratas for some versions.
 Are you just using ICSP, or ICD as well? (if the latter, there is a significant amount at the top of memory, that must not be used to make room for the ICD code). Also is the ICSP, a high voltage or low voltage programmer?. If the latter there is a specific problem with programming some parts of the memory at some voltages on these chips.
