how to get into a sub routine
umka
PostPosted: Sun Nov 18, 2007 7:44 pm     Reply with quote
i am writing a program and dont know how to get from the main routine into a differant one. say i have:
   some code
   While (1)
      read ADC
      if ADC == 10
         go to sub 1
      if ADC == 20
         got o sub 2
      line 1 display string 1
      line 2 display string 2
      line 3 display string 3
void sub 1 (viod)
   define string 1
   define string 2
   define string 3
void sub 2 (viod)
   define string 1
   define string 2
   define string 3
how does one get from the while (1) loop into the void sub1 (void) and void sub2 (void) to get 3 strings and then back into the while loop?
please help this is kind of urgent Embarassed
PostPosted: Sun Nov 18, 2007 9:12 pm     Reply with quote
See the program in this link. You call a function by name, and
give it parameters if that's part of the function's definition.
http://www.ccsinfo.com/forum/viewtopic.php?t=32168&start=1
umka
PostPosted: Mon Nov 19, 2007 12:17 am     Reply with quote
if i put all the sub routines in the while loop it runs out of rom.
in each sub routines there is 5 to 15 if statements so as to set the 3 strings.
once out of the sub i want the program to go back into the while loop witht he 3 string it has just gotten.
then display the strings on a lcd.
i have written the code but it is 1500 lines long in c so dont want to post unless u think this might help.
i just need a means of getting out of the while loop going through some if statements getting the 3 string and then returning to the while loop and displaying the string
PostPosted: Mon Nov 19, 2007 12:19 am     Reply with quote
What PIC are you using ?
Are you using the demo version of compiler ?
SET
PostPosted: Mon Nov 19, 2007 5:28 am     Reply with quote
Something like:
char *pstring1,*pstring2,*pstring3;
const char s1[] = "string1";
// etc
void sub_1 (void)
   pstring1 = s1;
   pstring2 = s2;
   pstring3 = s3;
void sub_2 (void)
   pstring1 = s4;
   pstring2 = s5;
   pstring3 = s6;
   // some code
   While (1)
      //read ADC
      if (ADC == 10 )
         sub_1();
      if (ADC == 20 )
         sub_2();
      display (line1,  pstring1);
      display (line2, pstring2);
      display (line3, pstring3);
umka
PostPosted: Mon Nov 19, 2007 1:59 pm     Reply with quote
sorry using a PIC16f877a
i think compiler is called pcm 4.038.
umka
PostPosted: Tue Nov 20, 2007 8:06 pm     Reply with quote
cheers set works a treat
