zhiling0229
How to generate this string? |
Posted: Fri Oct 06, 2006 9:39 am |
Hi guys,
I'm trying to implement a V-stamp speech synthesizer driver.
I required to generate the text, then followed by CR or NUL. Was wondering how can I terminate with CR or NUL. Here is my test program.
#include <16F877A.h>
#fuses XT, NOBROWNOUT, NOLVP, NOWDT
#use rs232(baud=2400, xmit=PIN_A2, rcv=PIN_A3)
struct lcd_pin_def
BOOLEAN B0; // B0
BOOLEAN B1; // B1
BOOLEAN B2; // B2
BOOLEAN B3; // B3
BOOLEAN B4; // B4
BOOLEAN B5; // B5
BOOLEAN B6; // B6
BOOLEAN B7; // B7
struct lcd_pin_def LCD;
#byte LCD = 0x06 // portB address on 16F877A
#use fast_io(D)
set_tris_b(0x00); // graphic lcd control lines all output
LCD.B0 = 1;
delay_ms(2000);
LCD.B0 = 0;
printf("Testing 1 2 3"); // What should I change here?
Posted: Fri Oct 06, 2006 10:27 am |
printf("Testing 1 2 3\r");
C supports various 'escape' characters. '\n', means 'LF', '\r', 'CR', etc..
You can generate any ASCII character, using \nnn, where 'nnn' is the 3 digit octal value to send, and \Xnn, using a hex value. It is standard in C, and mentioned in the manual, under 'expressions'.
Humberto
Posted: Fri Oct 06, 2006 10:32 am |
CR: Carriage Return
Is an old command name used in the Telex machines and electric typewriters.
It was used in conjunction with LF (Line Feed) whose hex equivalent is 0x0A.
#define CR 0x0D // CR: Carriage Return
printf("Testing 1 2 3%c", CR);
or
printf("Testing 1 2 3\r);
Humberto |
