digitalfreak
Computer shuts off |
Posted: Thu Sep 28, 2006 1:46 pm |
MPLAB7.42 + ICD2 (USB) + 18F8452 + PICC
Iam facing the following weird problem :
This happens randomly and I could not repeat its occurence.
When I start working on the project everything is fine and I could successfully connect, program and verify the program on the PIC using ICD2. Suddenly my computer shuts down, incidentally this happens
1. when I connect ICD2 to the powered target or
2. when I turn on the power of the target while it is connected to ICD2.
And it doenot happen every time the do the above.
It happened 4 times with in 15 hrs of working time, like I said it is random and I could not repeat it.
Interestingly I could not reprogram or connect to the target PICs, which were in use, while this horrible shut down happened. If I replace the PIC everything is normal again. I am worried that this might happen again. Can you please let me know what could make this happen?
I am assuming it got to do something with ICSP connections or some kind of ESD ??? .How can I protect my PICs and how can I stop the host computer turning off??
How can I upload image for schematic?
Following are the header and fuses i used....
#include <18F452.h>
#device adc=10
#use delay(clock=20000000, restart_wdt)
#fuses HS, PUT, BROWNOUT, NOWDT, NOLVP, NOCPD, NOPROTECT, NOWRT
#include <math.h>
Thanks in advance[/img] |
Posted: Thu Sep 28, 2006 1:54 pm |
This is really a Microchip ICD2 issue and not a CCS issue.
You should post it in the ICD2 forum. Also, tell them the O/S that
you're using (Windows XP SP2, etc.). Here's a link to the forum:
http://forum.microchip.com/tt.aspx?forumid=49
Also, on the Microchip forum, I believe you can upload images.
(Can't do that on this forum). |
digitalfreak
Posted: Thu Sep 28, 2006 2:19 pm |
Thanks |
Posted: Thu Sep 28, 2006 5:16 pm |
I notice that you posted it over there, but the schematic isn't viewable.
It shows a thumbnail image, but if I click on it, all I get is an "X" in a box.
I know that posting images can work, because here's a thread over
there that's near yours in the list and it has a picture of a breadboard
and clicking on it works just fine.
http://forum.microchip.com/tm.aspx?m=189927
You need to edit your post over there and fix the schematic.
Test it after you're done, to make sure it's viewable. |
