Need Advice Urgent
kocakaya
Need Advice Urgent
PostPosted: Sat Feb 10, 2007 6:15 am     Reply with quote
I made a 100 A car battery charger .There is 2x20 LCD and AN0 is Current Value Input AN1 is Voltage input. I want to write 24LC512 RAM and send to pc with Int_rda charging results. when battery voltage higher I am showing it with leds . My code is below Do you think is there a wrong in code When voltage is higher lcd showing speed gets faster because of led delays .Timers hold the amper hour .what can you advice ?
void besli() {
OUTPUT_HIGH(PIN_D4);
delay_ms(300);
OUTPUT_LOW(PIN_D4);
delay_ms(300);
OUTPUT_HIGH(PIN_C5);
delay_ms(300);
OUTPUT_LOW(PIN_C5);
delay_ms(300);
OUTPUT_HIGH(PIN_D3);
delay_ms(300);
OUTPUT_LOW(PIN_D3);
delay_ms(300);
OUTPUT_HIGH(PIN_D2);
delay_ms(300);
OUTPUT_LOW(PIN_D2);
delay_ms(300);
OUTPUT_HIGH(PIN_C2);
delay_ms(300);
OUTPUT_LOW(PIN_C2);
delay_ms(300);
void dortlu() {
delay_ms(300);
OUTPUT_LOW(PIN_C5);
delay_ms(300);
delay_ms(300);
OUTPUT_LOW(PIN_D3);
delay_ms(300);
delay_ms(300);
OUTPUT_LOW(PIN_D2);
delay_ms(300);
delay_ms(300);
OUTPUT_LOW(PIN_C2);
delay_ms(300);
void uclu() {
delay_ms(300);
OUTPUT_LOW(PIN_D3);
delay_ms(300);
delay_ms(300);
OUTPUT_LOW(PIN_D2);
delay_ms(300);
delay_ms(300);
OUTPUT_LOW(PIN_C2);
delay_ms(300);
void ikili() {
delay_ms(300);
OUTPUT_LOW(PIN_D2);
delay_ms(300);
delay_ms(300);
OUTPUT_LOW(PIN_C2);
delay_ms(300);
void tekli()
delay_ms(300);
OUTPUT_LOW(PIN_C2);
delay_ms(300);
void akimgerilim()
int adcdeger;
set_adc_channel( 1 );
delay_us(1);
value = Read_ADC();
deger=value/51;
value=value/51;
delay_us(1);
set_adc_channel( 0 );
delay_us(1);
adcdeger=Read_ADC();
max=adcdeger*1.5;
delay_us(1);
#INT_RDA
void yaz()
#INT_RTCC
void clock_isr() {
   high_count -= 1;
   akimgerilim();
   if(high_count==0)
   ++seconds;
   high_count=high_start;
   ahtoplam=ahtoplam+(max/3600);
   if(seconds>=60)
   dakika++;
   seconds=0;
   if(dakika>=60)
   saat++;
   dakika=0;
#int_TIMER1
void clock_isr2()
   high_count2 -= 1;
   if(high_count2==0)
   ++seconds2;
   high_count2=high_start;
   if(input(PIN_C1)==1)
   dakika2=dakika2+10;
   seconds2=0;
   if( input(PIN_C1)!=1 )
   if(seconds2>=60)
   dakika2++;
   seconds2=0;
   if(dakika2>=60)
   saat2++;
   dakika2=0;
   lcd_init();
   init_ext_eeprom();
   setup_adc_ports(AN0_TO_AN1|VSS_VDD);
   setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_0);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256|RTCC_8_bit);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   enable_interrupts(INT_RTCC);
   enable_interrupts(INT_RDA);
   set_timer0(0);
  do {
      lcd_putc("\f");
      delay_ms(1);
      lcd_gotoxy(1,1);
      lcd_putc("     M K P Micro ");
      lcd_gotoxy(1,2);
      lcd_putc("  Akuyu Baglayiniz");
      delay_ms(200);
   do {
       output_high(PIN_D7);
       delay_ms(250);
       output_low(PIN_D7);
       delay_ms(250);
      }while (deger<1);
       OUTPUT_HIGH(PIN_D7);
       lcd_putc("\f");
       delay_ms(1);
       lcd_gotoxy(1,1);
       lcd_putc("    Aku Baglandi\n");
       lcd_gotoxy(1,2);
       lcd_putc("     Bekleyiniz");
     for(a=0;a<3;a++)
       OUTPUT_D(0x9F);
       delay_ms(450);
       OUTPUT_D(0x00);
       OUTPUT_LOW(PIN_C5);
       OUTPUT_LOW(PIN_C2);
       delay_ms(450);
        lcd_putc("\f");
       if(deger<1>2.40)
         ariza=3;
         goto ariza10;
     OUTPUT_HIGH(PIN_D5);
     delay_ms(2000);
      system_start=1;
      set_timer1(0);
      asama=1;
      dakika=0;
      saat=0;
      seconds=0;
      ahtoplam=0;
      ilk=0;
      kademe=0;
      lcd_putc("\f");
      delay_ms(1);
   do {
         ariza=0;
         if(ilk==0)
         ilk=1;
         if(max<2)
         ariza=5;
         if(max<2)
         islemtamam=0;
         a1=0;
         ariza=4;
         lcd_gotoxy(1,1);
         printf(lcd_putc,"V:%01.2f ", value);
         lcd_gotoxy(12,1);
         printf(lcd_putc,"Ah:%2f.1",ahtoplam);
         lcd_gotoxy(1,2);
         printf(lcd_putc,"I:%03.1f ",max);
         lcd_gotoxy(13,2);
         printf(lcd_putc,"T:%02u:%02u",saat,dakika);
         if(value<2>=2.10 && value<2>=2.20 && value<2>=2.30 && value<2.40 && kademe==0)
         ikili();
         if(asama==4 || asama==5 || asama==6 || asama==7 || asama==8 || asama==9)
         tekli();
         if(saat2==10 && value<2>=2.30) && asama==1))
         asama=2;
         saat2=0;
         dakika2=0;
         seconds2=0;
         if(((saat2==2 && dakika2==30) && value<2>=2.35) && asama==2)
         asama=3;
         saat2=0;
         dakika2=0;
         seconds2=0;
         if(((saat2==1 && dakika2==30) && value<2>=2.40) && asama==3)
         asama=4;
         kademe=1;
         saat2=0;
         dakika2=0;
         seconds2=0;
         if(((saat2==1 && dakika2==30) && value<2>=2.45) && asama==4)
         asama=5;
         saat2=0;
         dakika2=0;
         seconds2=0;
         if(((saat2==1 && dakika2==30) && value<2>=2.50) && asama==5)
         asama=6;
         zaman=0;
         saat2=0;
         dakika2=0;
         seconds2=0;
         if(((saat2==1 && dakika2==30) && value<2>=2.55) && asama==6)
         asama=7;
         saat2=0;
         dakika2=0;
         seconds2=0;
         if(((saat2==1 && dakika2==30) && value<2>=2.6) && asama==7)
         asama=8;
         saat2=0;
         dakika2=0;
         seconds2=0;
         if(((saat2==1 && dakika2==30) && value<2>=2.65) && asama==8)
         asama=9;
         saat2=0;
         dakika2=0;
         seconds2=0;
         if(saat2==1 && asama==9)
         islemtamam=1;
         ariza=6;
         if(saat==14 && value<2>2.40)
         islemtamam=1;
         ariza=6;
         }while (TRUE);
Thanks for help
