In Circuit Programming using PICSTART Plus
arrow
PostPosted: Thu Sep 28, 2006 3:56 am     Reply with quote
Hi
I would like to do in circuit programming of a PIC18F2550 using the PICSTART Plus programmer.
I have a diode on the MCLR pin, and I can connect to the PGD and PGC pins, as well as the Vdd and Vss pins.
I use clips to go from the board to the PICSTART plus on these 5 lines (I have wires stickign out of the sockets).
My code is protected.
This does not seem to work. Can someone please tell me how to do this in circuit programming using the PICSTART Plus?
Thank you
a.
jfk1965
PostPosted: Thu Sep 28, 2006 6:51 am     Reply with quote
One thing to be careful of is the current drain on the VDD line. You may find your circuit draws more current than the programmer can supply.
I have come across this problem before and isolating the VDD from the rest of the circuit solved it.
arrow
PostPosted: Thu Sep 28, 2006 7:10 am     Reply with quote
Hi JFK1965
How can I isolate my Vdd line in circuit?
(Its already on a PCB).
What I have found in the past with other projects is that if I have NOPROTECT as my fuse setting then it reprograms fine.
However I had put it as PROTECT, and I cant seem to overwrite now.
Any suggestions would be greately appreciated.
Thank you
a.
jfk1965
PostPosted: Thu Sep 28, 2006 7:37 am     Reply with quote
arrow wrote:
Hi JFK1965
If you can't Isolate it you might have to increase the current available by using an external logic level fet and a 5V PSU. Measure the 5V line when your programming and check it's 5V.
JFK
PostPosted: Thu Sep 28, 2006 12:36 pm     Reply with quote
This thread has detailed instructions on how to use PicStart-Plus for ICSP:
http://www.ccsinfo.com/forum/viewtopic.php?t=5405&highlight=picstart+icsp
arrow
PostPosted: Fri Sep 29, 2006 1:11 am     Reply with quote
Hi PCM Programmer and JFK1965
Thank you for your help.
a.
