PIC16F628 - DIP SWITCH
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
Re: PIC16F628 - DIP SWITCH
PostPosted: Sat Sep 23, 2006 8:45 pm     Reply with quote
coseglio wrote:
##Urgent## SOS#SOS
Sounds like a homework.
coseglio wrote:
The while(1) loop i want is a infinite loop , but in my program execute only one and stop. I dont know wat is the problem with this.
You're calling getc() in the main loop without calling kbhit() first. It could be that your program waits forever for the input from the serial port. Also, it might help to add something like printf("heartbeat\n\r"); for debugging purposes at the very top or very bottom of the loop outside any if statements. Or to toggle an LED for the same purpose.
TEST
PostPosted: Sun Sep 24, 2006 7:04 am     Reply with quote
Hi Kender. Thanks for the information.
Can tiy see now that is correct?
#include <16F628A.h>
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP,NOMCLR
#include "usart.h"
#use delay (clock=4000000)
#use rs232(baud=9600,xmit=PIN_B2,rcv=PIN_B1)
SET_TRIS_A( 0x0F );
SET_TRIS_B( 0x0E );
unsigned char lerDip();
   unsigned char saida;
   unsigned char dados;
   unsigned char aux = 0x00;
   unsigned char mascara_a = 0xF0;
   unsigned char entra;
   unsigned char conf_dip;
   int1 fotodiodo;
   unsigned char endereco;
      conf_dip = lerDip();
      aux = (conf_dip | mascara_a);
      entra = 0x00;
      entra = kbhit();
      if(entra);
         dados = getc();
              if (dados == aux)
         fotodiodo = 0;
         fotodiodo = input(PIN_A0);
           if (fotodiodo)
           saida = 0xFF;
           printf("%c",saida);
          { saida = 0x00;
          printf("%c",saida);
   int8 a1;
   int8 a2;
   int8 a3;
   int8 res;
   res = 0x00;
   res |= a1;
   if (a1)
   res |= (a2 << 1);
   if (a2)
   res |= (a3 << 2);
   if (a3)
   return res;
