Will Reeve
Joined: 30 Oct 2003 Posts: 209 Location: Norfolk, England
How to switch off .tre generation? |
Posted: Tue Sep 12, 2006 5:21 am |
Hi all,
Hope you are all well. Is there a way I can switch off the .tre file generation as it's taking ages to generate. I use the PCW IDE and can't see an option to use -T with the "compile button" am I missing something?
Keep well,
Will |
Posted: Tue Sep 12, 2006 7:55 am |
In PCW v3.249: open Options/File Formats/Compiler and deselect 'Call tree file'. |
Will Reeve
Posted: Tue Sep 12, 2006 8:12 am |
Thank you, not sure what is up with the compiler but it was taking 5mins to generate that file, now 18Mb in size, you could watch the file size increase! Switch off it's generation and everything is back to normal! |
