byte and nibbles
alecrp
byte and nibbles
PostPosted: Thu Sep 07, 2006 8:17 am     Reply with quote
hi someone can help me?
i read two byte from the serial port of my pic in two variable
int value,value1;
value = getc();
value1=getc();
i must put the high nibble of value and the low nibbe of value1 (4 bit and 4 bit) in value3;
how?
thanks.
Humberto
PostPosted: Thu Sep 07, 2006 8:51 am     Reply with quote
Did you try it ?
If so, please show us to see how you do it and we will help you.
Humberto
CCS JIM
PostPosted: Thu Sep 07, 2006 8:54 am     Reply with quote
Use an and to clear out the lower nibble of value and then or it with the lower nibble of value1.
  value3 = (value & 0xf0) | (value1&0x0f);
If I mixed up the nibbles, just switch value and value 1.
