here some bugs in the PIC-Wizard at the PWM-Corner.
For Example: I have open the PIC-Wizard and select a 18F2431 Device.
Now I will create the PWM-Setup.
I select The Radio-Button "PWM".
Now open'd the Window "Enter Number".
I give a Number in this Window, the Wizard create the Setup,
but the Window "Enter Number" can not close.
The Wizard hangs. Only with "ctrl, alt, del" can Exit the Wizard.
dyeatman
Posted: Tue Sep 05, 2006 5:47 am
I hope you copied this to CCS... They don't watch this board as a rule.
