how to create global const in program
butterfly
PostPosted: Wed Sep 06, 2006 6:58 am     Reply with quote
normaly to create global const ;
const int16 MASK = 0x0000;
i want to read eeprom adm create global const like that
main(){
const int16 MASK = read_EEPROM (0x00);
and give this error:
*** Error 51 "C:\umut\um\alt1.c" Line 68(1,6): A numeric expression must appear here
how to make it happen?
PostPosted: Wed Sep 06, 2006 7:11 am     Reply with quote
What you describe, is impossible.
Simply declare a normal global variable, and read the EEPROM data into it. A_constant_ is 'read only', so, you cannot write data into it.
You can declare a variable that lives in EEPROM, using the typemod directive.
Your expression fails for two reasons. The first is the inability to write to a constant, while the second is that 'read_eeprom', is a function, only returning a value when it is run, while the constant declaration, occurs at compile time, so no value is available.
butterfly
PostPosted: Wed Sep 06, 2006 7:17 am     Reply with quote
thanks
how can i create a global various then
PostPosted: Wed Sep 06, 2006 7:28 am     Reply with quote
Any variable declared outside the subroutines, is 'global'. Declare a variable at the head of the program, and it is available to all the routines.
int16 value=0;
void demosub(void) {
   printf("%4ld/n",value);
void main(void) {
   demosub();
   value=10;
   demosub();
   while (TRUE) ;
This will print '0', and then '10', with 'value' being accessable inside both routines.
