18F4550 USB development kit crashes PC
robert
PostPosted: Fri Sep 01, 2006 5:58 am     Reply with quote
Can any one help, I am tryng USB for the first time and have the USB development kit for the PIC18F4550. I have programmed a simple example from the manual (ex7.c) that just checks for enumeration.
#include <18F4550.h>
#FUSES HSPLL                  //High Speed Crystal/Resonator with PLL enabled
#FUSES NOWDT                    //Watch Dog Timer
#FUSES NOPROTECT              //Code not protected from reading
#FUSES NOLVP                  //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NODEBUG                //No Debug mode for ICD
#fuses USBDIV                 //clock frequency configuration for USB
#fuses PLL5
#fuses CPUDIV1
#fuses VREGEN                 //USB voltage regulator enabled
# use delay(clock=48000000)
#ignore_warnings NONE           // report all warnings
#define LED1 PIN_A5
#define LED2 PIN_B4
#define LED3 PIN_B5
#define BUTTON PIN_A4
#define LED_ON output_low
#define LED_OFF output_high
#define USB_EPI_TX_ENABLE USB_ENABLE_INTERRUPT
#define USB_EP1_TX_SIZE 8
#define USB_EPI_RX_ENABLE USB_ENABLE_INTERRUPT
#define USB_EP1_RX_SIZE 8
# include <pic18_usb.h>        // Microchip 18Fxx5x hardware layer for usb.c
# include <usb_desc_hid.h>     // USB Configuration and Device descriptors for this UBS device
# include <usb.c>              // handles usb setup tokens and get descriptor reports
   LED_ON(LED1);
   LED_OFF(LED2);
   LED_OFF(LED3);
   usb_init();
      if (usb_enumerated())
         LED_ON(LED3);
         LED_OFF(LED3);
When I plug the USB device into the PC I get someting like:
New Hardware detected
Human Interface Device
Then the PC creashes with a restart. On restart the PC reports a catastrophic failure had occured and when I report to MS it comes back with the reason being "unknown driver". Same on two other PC's
OS: WINXP PRO
The LED3 lights so the crash comes after enumeration.
Thanks for any help
Darren Rook
PostPosted: Sat Sep 02, 2006 8:43 am     Reply with quote
Does example 8 crash the PC?
I came, I saw, I compiled.
robert
PostPosted: Mon Sep 04, 2006 3:02 am     Reply with quote
Thanks Darren,
I have just picked this up from someone thats left (the only expert we had in the company). I have found a test program he had made and it does not crash the pc. It looks that it is based on example 8 so it would seem that ex7 is a duff'n. Thats a pity as it doesnt give confidence to someone who does'nt really know what they are doing.
