guest Guest
GLCD troubles |
Posted: Thu Sep 14, 2006 11:24 pm |
Hi everyone
I am try to interface a GLCD (128 x 64) with PIC16f877A. The GLCD is the one that came with Easypic3 board, i think its ' 'Xiamen Ocluar GDB12864B' but im not too sure. What i do know for sure is that it uses 'KS0108' controller. The GLCD is not working in the sense that only half of the GLCD pixels (essentially 64x64) are visible and even in that some pixel lines are missing. No text or circle or whatever is in the
program is being displayed.
Here are the connection:
PIC : GLCD
B0 CS1
B1 CS2
GND GND
+5v Vcc
Vo is connected from a 20k Ohm POT
B2 RS
B4 R/W
B5 E
D0-D7 Databus (8 bit)
C0 Rst
VEE is connected to Negative voltage for 20k Ohm POT
+5 and Gnd for Backlight
Below is the code:
#include <16F877A.h>
#device *=16
#include <stdlib.h>
#include <string.h>
#include <24512.c> //for the atmel eeprom
#include <math.h>
#USE DELAY (CLOCK=10000000)
#include <glcd.c>
#fuses HS,NOWDT,NOLVP
#use rs232(baud=19200,xmit=pin_c4,rcv=pin_c5,parity=N,stream=pc)
setup_adc( ADC_OFF );
delay_ms(20);
glcd_init(ON); //initialize the LCD
fprintf(pc,"\n\rgraphical 1");
glcd_circle(30,30,5,NO,OFF);
Is there some need to pull up or pull down some pins or something like that. I have even tried interchanging the chipselect pins.
Please help!!!
Best Regards |
Markdem
Posted: Fri Sep 15, 2006 5:51 am |
Hello, I think that your problem mybe hardware related. If the LCD is only drawing half of the space, it sounds like the CS is not been pulled high. Check to see if the connection is OK. I would also check the rest of the pins to see if they are ok.
Also, when you use glcd_circle, you need to change it to:
glcd_circle(30,30,5,NO,ON);
Also, if you want to display text, you need to do smothing like this
sprintf(lcddata,"Light Bank 1");
glcd_text57(1,0,lcddata,1,on);
Have a look at EX_GLCD in the exampels folder for more info
Have Fun
Mark |
