structure pointers
eaton
structure pointers
PostPosted: Fri Sep 01, 2006 6:44 pm     Reply with quote
does the -> notation work in CCS. I can't seem to make it work.
(*struct_pointer).field will work but
struct_pointer->field doesn't work right.
any help would be greatly appreciated
PostPosted: Fri Sep 01, 2006 6:55 pm     Reply with quote
Look at the PCF8583 driver that I've posted in the Code Library.
It uses structure pointers in the two main functions that read and set
the date and time.
http://www.ccsinfo.com/forum/viewtopic.php?t=27988
If that doesn't help, then post the following:
1. The PIC that you're using.
2. Your compiler version.
3. A very small, but complete test program that demonstrates the problem.
