Time Delay with condition loop.
Eleengnrng
PostPosted: Tue Aug 29, 2006 9:54 am     Reply with quote
Hello I am trying to get a loop to execute for 8s then exit or exit if the external interrupt is triggered the interrupt is active low. Here is what I have tried and other combinations. I am using a PIC16F877 at 20Mhz Clock; all the proper tris registers are set and interrupts. I have been able to have the loop terminate after the interrupt is triggered but cant seem to get the delay to work.
while((input(PIN_B0)!=0)&&(delay_ms(8000))){
      output_high(PIN_A4);// Turn Buzzer on
      output_low(PIN_A4); // turn buzzer off
Any help is appreciated.
PostPosted: Tue Aug 29, 2006 10:13 am     Reply with quote
The delay function, does not return a value, so cannot be used in a conditional test. You could do what you show with either:
[code]
do {
} while (delay_ms(8000),input(PIN_B0));
[code]
or
[code]
while (input(PIN_B0)) {
delay_ms(8000);
[/code]
The first will raise the pin, wait eight seconds, then test the input pin, while the latter tests the pin before starting.
Humberto
PostPosted: Tue Aug 29, 2006 10:39 am     Reply with quote
If you want to exit the loop if the EXTernal INTerrupt is triggered, you would do
something like this:
int8 counter;
#INT_EXT
void EXT_inte()
  counter = 1;   // At worst case will add 40ms of latency
}                // but is safest than counter = 0
in main....
   ext_int_edge(H_to_L);
   enable_interrupts(INT_EXT);
   counter = 200;
   do
      output_high(PIN_A4);  // Turn Buzzer on
      delay_ms(40);         //  200*40=8000
      counter--;
     }while(counter);
   output_low(PIN_A4);     // Turn Buzzer off
Humberto
MikeW
PostPosted: Wed Aug 30, 2006 1:03 am     Reply with quote
The way i do these sort of things is by having a timer isr which sets flags to signify a timing period is over. Then in the main loop, just check the timeout flag for being set. That way, you can check for your event change, be it a pin change, or interrupt change, and act accordingly.
hope this has helped.
