cheap PIC w/ CAN?
jma_1
cheap PIC w/ CAN?
PostPosted: Sat Aug 19, 2006 11:36 am     Reply with quote
Greetings,
I'm looking for suggestions on an inexpensive 8 bit processor with CAN. The PIC 18F2480 looks like the least inexpensive offered by Microchip. The part is ~ $5 - 6 with extended temperature range and quantity. However, I do not need all the 25 I/O pins (overkill). I'm looking for ~ 10 I/O with CAN (but cheaper < $5).
Any suggestions? How about Atmel, Siemens, TI, Holtek, Renesas, Freescale or ? How about using an FPGA w/ a soft-core CAN module?
Thanks for your time,
JMA
jecottrell
PostPosted: Sat Aug 19, 2006 3:53 pm     Reply with quote
PIC (get it?) your MCU and then add a CAN transceiver (MCP2551 $1.45 ea. @ Digikey).
Quick, simple, and easy.... No?
Good luck,
John
kender
PostPosted: Sat Aug 19, 2006 4:18 pm     Reply with quote
Not quite that simple (at least for me). There should also be a hardware suppot for CAN on the PIC or MCP2515, shouldn't it?
jecottrell
PostPosted: Sun Aug 20, 2006 12:17 pm     Reply with quote
Nick,
I just looked at an app note AN212 and it uses a MCP2510 then a MCP2551. So apparently more hardware is involved, i.e. a CAN controller then a CAN driver. I'm learning as I go.......
So, to use a smaller PIC would require two extra peripheral devices with their added cost, complexity, and supporting components.
I would go with the PIC with on board CAN and leave the unused IO alone....
John
Storic
PostPosted: Sun Aug 20, 2006 4:15 pm     Reply with quote
Yep,
I went through a similar exercise where I wanted to use a small 24F micro, it looks like I will be using the 100 Pin version for the peripherals instead of adding the extra's. As for the spare pins, I layed the board out so I could access them easily so if I was looking at changes, extentions or even a new design I counld use this board.
Andrew
What has been learnt if you make the same mistake? Wink
PostPosted: Sun Aug 20, 2006 5:20 pm     Reply with quote
Some info on several of all possible manufacturers:
- Microchip, many choices. PIC18F2480 starts from $4.30
- Atmel has only few CAN processors. AT90CAN128 too expensive, cheaper AT90CAN32 starts sampling 06Q3
- Philips, several ARM based processors: LPC2119 from $7.60
- Renesas has several processors with CAN, and many under development. H8 based HD64F36054 from $8.60
For processors from other manufacturers you'll have to do your own investigations.
jma_1
PostPosted: Mon Aug 21, 2006 5:55 am     Reply with quote
Thanks ckielstra,
I found the same processors you listed. If I find anything less expensive I'll post a link to it.
Cheers,
JMA
iso
PostPosted: Mon Aug 21, 2006 11:49 am     Reply with quote
jecottrell, the 2551 is just a transceiver. You must mean a stand-alone can 2515 right ?
Don't worry about 'wasting' io pins as long as you have the room for the package it doesn't matter. I've found I will always end up needing at least 2-5 more io pins then I originally figure when doing a new project.
The 28pin QFN pics are the smallest processors with CAN anywhere out there I beleive.
I've dealt with microchip can a lot and I recommend it. Not overly complicated and I have yet to find any glaring design flaws. I have no reservations about using microchip CAN in any of my projects.
Try pic with internal can + transceiver (2551 is decient and cheap) or you have the small cheap pic + 2515 + 2551. The only requirement you have with the 2515 option is your pic should really have hardware spi... but you could do it in software.
