set_tris question
set_tris question
PostPosted: Sat Aug 19, 2006 11:25 am     Reply with quote
Hello, I'm making a driver and was wondering if the following is possible.
I have a particluar I/O pin (VPP) defined as:
#byte PORTD = 8
#bit VPP=PORTD.6
Is there a way in the function to modify the tris reg of VPP having only been passed VPP?
I know that on this device the port is in bank 0 and the tris is at the same location in bank 1. Something to the effect of:
VPP + 0x80 = 1 to make it an input
VPP + 0x80 = 0 to make it an output
Thanks!
PostPosted: Sat Aug 19, 2006 12:10 pm     Reply with quote
The code shown in the links in this thread, tells how to do it.
http://www.ccsinfo.com/forum/viewtopic.php?t=27923&highlight=16f+18f
