Syntax Question..
Joseph88
Syntax Question..
PostPosted: Wed Aug 23, 2006 4:53 am     Reply with quote
Hello PIC C Professionals!
I'm getting a "Bad Syntax Error" when I compile the code indicated below, does anyone have any ideas?
lcd_putc("\fHello World\n", 1); <--get error here. works if I don't have the extra "1" argument added.
void lcd_putc(char* c, int8 lcdNum)
switch(c)
case '\f':
lcd_send_byte(0,1,lcdNum);
delay_ms(2);
case '\n':
lcd_gotoxy(1,2,lcdNum);
case '\b':
lcd_send_byte(0,0x10,lcdNum);
default:
lcd_send_byte(1,c,lcdNum);
Any ideas? As mentioned above, this code works if I don't have the extra argument for lcd_putc.
Thanks for the help!
J
rberek
PostPosted: Wed Aug 23, 2006 8:28 am     Reply with quote
lcd_putc only accepts a single argument, which is a character string, so it won't like you adding another argument.
What were trying to accomplish with the extra argument?
PostPosted: Wed Aug 23, 2006 9:12 am     Reply with quote
Hi rberek
Thanks for taking the time to reply to my post. I'm trying to write code for multiple LCD's. So instead of having multiple lcd_putc functions, i'd like to use just one.
J
Mark
PostPosted: Wed Aug 23, 2006 9:46 am     Reply with quote
Then you have to change the lcd_putc to include the second argument.
