RS232 using MPLAB UART1
Robert@panik
PostPosted: Thu Aug 10, 2006 10:30 am     Reply with quote
Hi Folks,
I am new to this compiler and have a question about using UART1 to simulate input. It works fine in ASM but a simular C version hanges on the getc() and does not take the input from the text file. My progam is very simple
#include <18F4550.h>
#ignore_warnings NONE           // report all warnings
#define CLOCK_48MHz             // micro clock frequency
#include <stdlib.h>
#include <STRING>
#include <CTYPE>
#include <STDDEF>
#use delay(clock=48000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,bits=8,parity=n)
   int8 x=0x55;
      putc(x);
      x=getc();
Does this mplab feature work with the compiler or is there a problem with the code snippet.
PS the unital 'U' character is displayed in the display box.
Regards
Robert.
PostPosted: Thu Aug 10, 2006 11:28 am     Reply with quote
The text file that you give to UART1 has to have the text in quotes.
Example:
"ABCDEFGHIJKLMNOPQRSTUVWXYZ"
robert@panik
PostPosted: Fri Aug 11, 2006 12:48 pm     Reply with quote
Thanks , but I found the problem, I had the wdt on used a #fuse to define NOWDT and it worked.
Robert
