WTB Guest
SPI Problems - Only reading every other byte |
Posted: Fri Aug 11, 2006 9:25 am |
I'm having problems with SPI communication between two PIC's. I want to send data from a pic 18f4680 to a pic 16f876. I've written some test code that increments an int8 up and down between 0 and 255, sending each value over the SPI port. The result I get at the other end seems to miss every other byte so instead of '1,2,3,4,5 . . .' I get '1,3,5,7,9 . . .'
I can only get it to work if I use two write_spi(x) calls together - effectively sending each byte twice.
Can anyone explain whats going on?
Here is the transmitter code
#include "D:\PIC_C_Projects\PGS\Controller\Cont.h"
//From header
#include <18F4680.h>
#device adc=10
//#FUSES HS //High speed Osc (> 4mhz)
#FUSES H4 //High speed osc with HW enabled 4X PLL
#FUSES BORV43 //Brownout reset at 4.3V
#FUSES XINST //Extended set extension and Indexed Addressing mode
#FUSES LPT1OSC //Low Power Timer OSC1
//#FUSES NOXINST //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(clock=32000000)
void SPISendByte(int8 Value)
//This Works
spi_write(Value);
delay_us(10);
spi_write(Value);
//But not this
spi_write(Value);
int8 InByte1;
#zero_ram
int8 OutByte;
signed int16 Dir;
setup_adc_ports(AN0_TO_AN6|VSS_VDD);
setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_0);
setup_psp(PSP_DISABLED);
setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_16);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_DIV_1|RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED|T2_DIV_BY_1,255,1);
setup_vref(FALSE);
setup_oscillator(False);
OutByte = 0;
Dir = 1;
//just to test count up and down then transmit over SPI
OutByte += Dir;
if(OutByte > 254) Dir = -1;
if(OutByte < 1) Dir = 1;
//send the byte
SPISendByte(OutByte);
delay_ms(50);
putc(OutByte);
And the reciever code
#include "D:\PIC_C_Projects\PGS\SEA_Pic16f876\SEA_Controller.h"
//From Header
#include <16F876.h>
#device adc=10
//#include "Fixed.h"
#FUSES NOWDT
#FUSES HS
#FUSES PUT
#FUSES NOLVP
int8 SPIData;
int1 NewData;
int8 SPIBuff[64];
int8 index;
#INT_SSP
SSP_isr()
//collect incoming SPI data into a buffer
SPIBuff[index] = spi_read(0);
index++;
if(index > 63)
index = 0;
NewData = 1;
VOID main()
int8 Out = 0;
setup_adc_ports(ALL_ANALOG);
setup_spi(SPI_SLAVE|SPI_L_TO_H|SPI_CLK_DIV_4|SPI_SS_DISABLED);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_16);
//setup_timer_2(T2_DIV_BY_16);
enable_interrupts (INT_SSP);
enable_interrupts (GLOBAL);
NewData = 0;
index = 0;
WHILE (1)
if(NewData == 1)
//if the buffer is full empty it over the USART
for(Out = 0; Out < 64; Out++)
putc( SPIBuff[Out] );
NewData = 0;
Posted: Fri Aug 11, 2006 10:11 am |
You are creating the 'heart' problem, for yourself, by having the '0' in the SPI_READ command.
At heart, the CCS spi functions, are not well written for interrupt use. In the interrupt, if you do want to send data back, on the slave device, all that is needed is to read the register contents, then write the new byte back, and exit the interrupt. However the CCS function, if asked to write a byte back, will _wait_ for it to transfer. So by having the '0' here, you are forcing two transfers to have to occur, for each loop of the interrupt handler (one to send the byte and force the interrupt, and a second to clock back the reply)...
If you don't want to transfer data back, then get rid of the zero. You will also need to have the 10uSec delay after any transfer, since it takes about 6uSec after the byte completes for the 'slave' device to actually get into the interrupt handler. Your second transfer is working without the delay, because the slave is sitting 'waiting' in the handler.
If you do want to do transfers both ways, I have an alternative set of SPI functions, optimised for use with interrupts, which I have posted in the past, and if you want bi-directional useage, I have a newer version that I can post.
WTB Guest
Posted: Fri Aug 11, 2006 10:19 am |
Thanks for that, it now works. An example of how to return data would be appreciated as well though.
What I am trying to do eventually is to send a signed int16 over the SPI and get a signed int16 back. |
