i'm using pic16f877a and want to use its internal eeprom.
i tried write_ext_eeprom() funtion bot its nor work...
any help...
ttelmah Guest
Posted: Wed Sep 06, 2006 2:31 am
write_eeprom.
There are three different 'memory' functions (depending on the chip, and the memory involved):
write_program_eeprom - writes to the _program_ memory
write_eeprom - writes to the internal eeprom
write_ext_eeprom - writes to an _external_ eeprom (hence the 'ext').
