nurquhar
Joined: 05 Aug 2006 Posts: 149 Location: Redditch, UK
Why does my PIC skip GOTO ? What could be wrong ? |
Posted: Tue Aug 08, 2006 2:54 am |
I have some simple code that the complier (V3.249) is generating GOTO's to implement (even though I have used #separate for the function call!). The source code and assembley below.
I am using Microchip ICD2 to trace the code on a PIC16F648_ICD chip plugged into may target.
If I set a breakpoint on a NOP before or after the check_rx() and run the traget it will halt at the expected instruction. If I move the break point to the NOP at the begining of the check_rx() function and run the traget from the beginning again then the break point is never reached !!
What is realy unexplainable is if I single step (step into) through this bit of code in main()
0460: NOP
.................... nop() ;
0461: NOP
.................... check_rx() ;
0462: GOTO 3B7
0463: NOP
then it never does the GOTO 3B7 it just steps to the next NOP at 0463.
If I carry on single stepping it also fails to do the GOTO 45F and effectivley exits the while(1) {} loop, it runs through the GOTO at the end of main loop also, ie its crashed !!
0463: NOP
0464: NOP
0465: NOP
0466: GOTO 45F
The source ..........................................................
#separate
void check_rx()
char ch ;
nop() ;
nop() ;
nop() ;
// Check for overrun error
if (OERR) {
// Clear the error
CREN = 0 ;
CREN = 1 ;
mstcp_rawin(0, MSTCP_OVERRUN_ERR) ;
nop() ;
nop() ;
nop() ;
// Check for framing error
if (FERR) { \
ch=RCREG ;
mstcp_rawin(ch, MSTCP_FRAME_ERR) ;
nop() ;
nop() ;
nop() ;
// Check for command
if(kbhit()) {
ch = getc() ;
mstcp_rawin(ch, MSTCP_DATA_RX) ;
nop() ;
nop() ;
nop() ;
main()
while(1) {
nop() ;
nop() ;
nop() ;
check_rx() ;
nop() ;
nop() ;
nop() ;
The relavant snippets are from the LST file are :
CCS PCM C Compiler, Version 3.249, 33800 08-Aug-06 08:57
Filename: LinLED_01.lst
ROM used: 1137 words (30%)
Largest free fragment is 1792
RAM used: 63 (38%) at main() level
89 (53%) worst case
Stack: 6 worst case (5 in main + 1 for interrupts)
0000: NOP
0001: MOVLW 00
0002: MOVWF 0A
0003: GOTO 3E0
.................... #separate
.................... void check_rx()
.................... char ch ;
03B7: NOP
03B8: NOP
03B9: NOP
.................... // Check for overrun error
.................... if (OERR) {
03BA: BTFSS 18.1
03BB: GOTO 3C2
.................... // Clear the error
.................... CREN = 0 ;
03BC: BCF 18.4
.................... CREN = 1 ;
03BD: BSF 18.4
.................... mstcp_rawin(0, MSTCP_OVERRUN_ERR) ;
03BE: CLRF 5E
03BF: MOVLW 87
03C0: MOVWF 5F
03C1: CALL 238
03C2: NOP
03C3: NOP
03C4: NOP
.................... // Check for framing error
.................... if (FERR) { \
03C5: BTFSS 18.2
03C6: GOTO 3CE
.................... ch=RCREG ;
03C7: MOVF 1A,W
03C8: MOVWF 5D
.................... mstcp_rawin(ch, MSTCP_FRAME_ERR) ;
03C9: MOVF 5D,W
03CA: MOVWF 5E
03CB: MOVLW 86
03CC: MOVWF 5F
03CD: CALL 238
03CE: NOP
03CF: NOP
03D0: NOP
.................... // Check for command
.................... if(kbhit()) {
03D1: BTFSS 0C.5
03D2: GOTO 3DB
.................... ch = getc() ;
03D3: BTFSS 0C.5
03D4: GOTO 3D3
03D5: MOVF 1A,W
03D6: MOVWF 5D
.................... mstcp_rawin(ch, MSTCP_DATA_RX) ;
03D7: MOVF 5D,W
03D8: MOVWF 5E
03D9: CLRF 5F
03DA: CALL 238
03DB: NOP
03DC: NOP
03DD: NOP
03DE: BCF 0A.3
03DF: GOTO 463 (RETURN)
.................... while(1) {
045F: NOP
0460: NOP
0461: NOP
0462: GOTO 3B7
0463: NOP
0464: NOP
0465: NOP
0466: GOTO 45F
