LIN bus and EUSART
Fabri
LIN bus and EUSART
PostPosted: Tue Dec 27, 2005 3:21 am     Reply with quote
Hi Everybody,
I'm writing a code for LIN bus master mode.
As reported in datasheet of PIC16F690 there is a possibiliti to send a break sequence automatically setting TXEN and SENDB bits in TXSTA register.
is this mode supported by CCS ?
Shall I change the TXSTA bit manually in second time ?
Have you got any suggest about ?
Thanks for help,
ploana
PostPosted: Wed Aug 09, 2006 3:25 am     Reply with quote
Hi
you will need EUSART only for slave mode.
If you use the CCS Comiler and you use #rs232() you will have bi problems by changing the pins manually.
For master Mode by LIN-Bus:
putc(0x0F) with UART-speed of 20000kBit/s 250µs-5ms(Wake up)
delay_ms(130) wait 100-150ms
and then you can begin with your Header frame:
//sync Break
set_uart_speed( 13000 );
putc(0x00);
//sync Field
set_uart_speed( 19200 );
putc(0x55);
then you can send your protected identifier with putc( ... ); ...
Fabri
PostPosted: Thu Aug 10, 2006 12:05 am     Reply with quote
Hi ploana,
At the moment project with LIN BUS stopped.
Thanks for help anyway.
Regards,
Fabri
