KamPutty Guest
| Pic18F4520 Osc questions ~OR~ Brain farts! HELP! |
Posted: Thu Aug 03, 2006 5:36 pm |
Hi all,
I've got the major case of brain farts here. Question about osc fuses...
Setup: CCS Software Proto Board w/20Mhz crystal, pic18f4520
My WORKING fuses etc for 20mhz is
#fuses HS
This says to me, "High Speed Crystal/Resonator" or 20mhz
~NOW~
I want to go faster!
#1. I could use the internal 8mhz osc with 4x PLL = 32Mhz. What fuses would I need? All I can find is the INTRC_IO for 8mhz, how do I apply the 4x?
Thanks in advance!
~Kam (^8* |
Posted: Thu Aug 03, 2006 5:40 pm |
| Quote: | | What fuses would I need? All I can find is the INTRC_IO for 8mhz. |
Scroll down in the 18F4520.h file until you get to the setup_oscillator()
section. |
Posted: Thu Aug 03, 2006 6:30 pm |
| PCM programmer wrote: |
section. |
Thanks for the pointer! Makes more sense...
NOW I still have an issue!
Here is my code:
#include <18F4520.h>
#device adc=10
#FUSES BORV25 //Brownout reset at 2.5V
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
//#FUSES HS //20mhz mode
#fuses INTRC_IO // internal 8mhz osc
#use delay(clock=32000000)
//#use delay(clock=8000000)
setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_PLL_ON);
output_low(PIN_B0);
output_toggle(PIN_B0);
I think I have the settings correct(?) The delay is not working correctly.
Also, I'm assuming in the #use delay I enter the NEW speed(32000000), yes?
Also, the manual (CCS) says that using a #fuses INTRC_IO with a valid #use delay, this step (setup_osc) is done automagically...
Well, thanks again for the help!
~Kam (^8* |
Posted: Thu Aug 03, 2006 7:59 pm |
What is your version of the compiler ? Here is the oscillator setup code
generated by PCH vs. 3.249 for your program. It looks like it should
work.
... setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_PLL_ON);
0048: MOVLW 72 // Setup for 8 MHz with internal oscillator
004A: MOVWF FD3 // OSCCON register
004C: MOVLW 40 // Enable PLL for IntOsc
004E: MOVWF F9B // OSCTUNE register
0050: MOVF FD3,W // Read OSCCON register
Posted: Thu Aug 03, 2006 9:11 pm |
PCM Progammer,
Here is my listing:
.................... setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_PLL_ON);
0044: MOVLW 72
0046: MOVWF FD3
0048: CLRF F9B
004A: MOVF FD3,W
Here's yours
004C: MOVLW 40 // Enable PLL for IntOsc <---- MISSING FROM MINE!
I'm missing a line!
My compiler(s) version is 3.234.
I'm starting to feel sad now...
~Kam |
Posted: Thu Aug 03, 2006 10:33 pm |
Fix it by adding the two lines shown below.
#byte OSCTUNE = 0xF9B // Add this line
OSCTUNE = 0x40; // PLL ON Add this line
Posted: Fri Aug 04, 2006 9:53 am |
| PCM programmer wrote: | Fix it by adding the two lines shown below.
PCM Programmer,
I added the lines your suggested, and the asm looks right, but there is still an issue with the time! It's still taking approx 2 sec for the "delay_ms(500)" command!
Any Thoughts?
BTW, thanks for all your help!
~Kam (^8*
0000: GOTO 002C
.................... #include <18F4520.h>
.................... //////// Standard Header file for the PIC18F4520 device ////////////////
.................... #device PIC18F4520
.................... #list
.................... #device adc=10
.................... #FUSES NOWDT //No Watch Dog Timer
.................... #FUSES NOPROTECT //Code not protected from reading
.................... #FUSES BROWNOUT //Reset when brownout detected
.................... #FUSES BORV25 //Brownout reset at 2.5V
.................... #FUSES NOPUT //No Power Up Timer
.................... #FUSES NOCPD //No EE protection
.................... #FUSES STVREN //Stack full/underflow will cause reset
.................... #FUSES NODEBUG //No Debug mode for ICD
.................... #FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
.................... #FUSES NOWRT //Program memory not write protected
.................... #FUSES NOWRTD //Data EEPROM not write protected
.................... #FUSES IESO //Internal External Switch Over mode enabled
.................... #FUSES FCMEN //Fail-safe clock monitor enabled
.................... #FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
.................... #FUSES NOWRTC //configuration not registers write protected
.................... #FUSES NOWRTB //Boot block not write protected
.................... #FUSES NOEBTR //Memory not protected from table reads
.................... #FUSES NOEBTRB //Boot block not protected from table reads
.................... #FUSES NOCPB //No Boot Block code protection
.................... #FUSES LPT1OSC //Timer1 configured for low-power operation
.................... #FUSES MCLR //Master Clear pin enabled
.................... #FUSES NOXINST //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
.................... //#FUSES HS //20mhz mode
.................... #fuses INTRC_IO // internal 8mhz osc
.................... #use delay(clock=32000000)
0004: CLRF FEA
0006: MOVLW 07
0008: MOVWF FE9
000A: MOVF FEF,W
000C: BZ 0028
000E: MOVLW 0A
0010: MOVWF 01
0012: CLRF 00
0014: DECFSZ 00,F
0016: BRA 0014
0018: DECFSZ 01,F
001A: BRA 0012
001C: MOVLW 5F
001E: MOVWF 00
0020: DECFSZ 00,F
0022: BRA 0020
0024: DECFSZ FEF,F
0026: BRA 000E
0028: GOTO 005E (RETURN)
.................... //#use delay(clock=8000000)
.................... #byte OSCTUNE = 0xF9B
.................... void main()
002C: CLRF FF8
002E: BCF FD0.7
0030: CLRF FEA
0032: CLRF FE9
0034: MOVF FC1,W
0036: ANDLW C0
0038: IORLW 0F
003A: MOVWF FC1
003C: MOVLW 07
003E: MOVWF FB4
0040: MOVF FB4,W
0042: BCF FA1.6
0044: MOVLW 72
0046: MOVWF FD3
0048: CLRF F9B
004A: MOVF FD3,W
.................... OSCTUNE = 0x40; // PLL ON
004C: MOVLW 40
004E: MOVWF F9B
.................... output_low(PIN_B0);
0050: BCF F93.0
0052: BCF F8A.0
.................... while(1)
.................... delay_ms(500);
0054: MOVLW 02
0056: MOVWF 06
0058: MOVLW FA
005A: MOVWF 07
005C: BRA 0004
005E: DECFSZ 06,F
0060: BRA 0058
.................... output_toggle(PIN_B0);
0062: BCF F93.0
0064: BTG F8A.0
0066: BRA 0054
0068: SLEEP
Configuration Fuses:
Word 1: C800 IESO FCMEN INTRC_IO
Word 2: 1E1F BROWNOUT NOWDT BORV25 NOPUT WDT32768
Word 3: 8700 PBADEN CCP2C1 LPT1OSC MCLR
Word 4: 0081 STVREN NODEBUG NOLVP NOXINST RESERVED
Word 5: C00F NOPROTECT NOCPD NOCPB
Word 6: E00F NOWRT NOWRTD NOWRTC NOWRTB
Word 7: 400F NOEBTR NOEBTRB
Posted: Fri Aug 04, 2006 2:41 pm |
This thread on the Microchip forum offers some help:
http://forum.microchip.com/tm.aspx?m=145909&mpage=1
Based on that advice, try the following setup code. See if it works.
#byte OSCCON = 0xFD3
// setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_PLL_ON);
OSCCON = 0x70; // 8 MHz, Primary Oscillator
| Success! |
Posted: Sat Aug 05, 2006 11:53 am |
PCM Programmer,
Thanks for all the help! I came across the SAME thread this morning (did not read your message), changed the 0x72 to 0x70, and with your earlier suggestions, it works!
| Code: | #fuses INTRC_IO // internal 8mhz osc
setup_oscillator(OSC_8MHZ|OSC_NORMAL|OSC_PLL_ON);
output_low(PIN_B0);
All I changed in the OR's was the OSC_NORMAL (0x00 vs. 0x02).
I was coming to report my new findings to the board, but alas, you beat me to it!
Again, thanks for all your help.
~Kam (^8* |
