what are valid preprocessor directives for #pragma
pdswar
PostPosted: Mon Jul 31, 2006 9:10 am     Reply with quote
I was wondering if anyone knew what are some valid preprocessor directives for #pragma in CCS PCH C compiler.
What is an equivalent statement for the following in CCS:
#pragma fastcall Timer8_1_EnableInt
Wikipedia says that " The Register or fastcall calling convention is compiler-specific for historical reasons. In general, however, it states that the few first arguments that fit into a processor's register (i.e. with a size up to 32 bits for x86 architecture) will be passed via registers instead of being put onto the stack."
PostPosted: Mon Jul 31, 2006 11:35 am     Reply with quote
Pragma, actually does almost nothing...
It will accept _any_ command that the compiler accepts as a preprocessor directive (device statements, delay statements, etc. etc.). It's 'function', is simply to ensure that these are evaluated _first_.
There is no equivalent to the command you post, since this requires the presence of multiple registers on the processor. The PIC, only has one (8 bit accumulator) register.
pdswar
thanx
PostPosted: Thu Aug 03, 2006 9:54 am     Reply with quote
Ttelmah, thank you for the info.
I decided not to use #pragma.
