MAX7219 Display Driver using hardware SPI
Bill Legge
PostPosted: Wed Sep 22, 2010 10:34 pm     Reply with quote
Code tested on PIC18F8722 with 10MHz xtal. Runs OK at 10MHz(HS) and at 40MHz(PLL or H4).
The 'BAUD=10000' in the '#use spi' can also be left out.
// Project:    8722 SPI_02\main.c                                          //
// Author:     WVL                                                         //
// Date:       September 2010                                              //
// Outline:    Basic hardware SPI to drive ETT display with decode on:     //
//             BIGPIC5 board                                               //
//             Heartbeat portH.0                                           //
//             10Mhz Xtal run at 10Mhz using HS                            //
//             40MHz OK but slower used for good scope display
//             Using hwr SPI driving MAX7219                               //
// Pin assignments BIGPIC5 board                                           //
//             PIN         FUNCTION                                        //
//             C1          MAX load                                        //
//             C3          SPI clock                                       //
//             C4          SPI data in                                     //
//             C5          SPI data out                                    //
// Pin assignments ETT 8 digit display                                     //
//             C0          SPI data in                                     //
//             C1          Max load                                        //
//             C2          SPI clock                                       //
#define     DATA       PIN_C5    // SPI1 hardware SPI data out
#define     LOAD       PIN_C1    // software SPI
#define     CLK        PIN_C3    // SPI1 hardware clock
#include <main.h>
#define  LED PIN_H0
// MAX7219 needs: MSB first(default),data on rising clock edge
// Works at maximum rate OK, BAUD rate set for good scope display
#use spi(FORCE_HW,BAUD=10000,SAMPLE_RISE,BITS=8,)
// function to write two bytes to the display
// address_1=RH digit, address_8=LH digit
// decode is on so dis_data=3 displays '3'
void display(char address,char dis_data)
   output_low(LOAD);
   spi_write(address);     // spi1 write to default pins
   delay_us(10);           // used for scope display but not necessary
   spi_write(dis_data);    // spi1 write to default pins
   output_high(LOAD);
   unsigned int8 x;
   unsigned int8 y;
   setup_adc(ADC_CLOCK_DIV_2|ADC_TAD_MUL_0);
   setup_spi2(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_OFF);            // PIC18 only
   setup_timer_1(T1_DISABLED);
   setup_ccp1(CCP_OFF);
   display(0x0f,0x00);                 // test mode off
   display(0x0B,0x07);                 // scan limit - 8 columns
   display(0x0C,0x01);                 // Shutdown - normal mode
   display(0x09,0xFF);                 // decode mode on
   display(0x0A,0x07);                 // intensity
   for(x=1;x<=8;x++)display(x,0x0f);   // blank all digits
   while(true)
   for(x=1;x<=8;x++)       // write 1 to 8 on digits 1 to 8
      display(x,x);
      output_toggle(LED);
      }// for loop
   for (y=0;y<=9;y++)      // write 0 to 9 on all digits
      for (x=1;x<=8;x++)
         display(x,y);
         }// for x loop
      }// for y loop
   }// while loop
}// main loop
Anyone spots anything daft - please let me know?
Denmark in West Australia
'Where the forest meets the sea'
Bill Legge
PostPosted: Fri Sep 24, 2010 5:36 pm     Reply with quote
Code works OK but 'PCM programmer' has just kindly pointed out that the line that I thought turned 'SPI2' off did not do so - I've corrected the line in this listing:
// Author:     WVL                                                         //
//             BIGPIC5 board                                               //
//             PIN         FUNCTION                                        //
//             C1          MAX load                                        //
//             C3          SPI clock                                       //
//             C1          Max load                                        //
//             C2          SPI clock                                       //
#include <main.h>
#define  LED PIN_H0
   output_low(LOAD);
   output_high(LOAD);
   unsigned int8 x;
   unsigned int8 y;
   setup_spi2(FALSE);              // this is the corrected line ************
   setup_wdt(WDT_OFF);
   while(true)
      display(x,x);
      output_toggle(LED);
      }// for loop
      for (x=1;x<=8;x++)
         display(x,y);
         }// for x loop
      }// for y loop
   }// while loop
}// main loop
Regards Bill Legge
