		| Author | Message |
		| arunb
				| Kindly help with strange operation of 16F877A mcu |
				|  Posted: Tue Aug 01, 2006 11:09 pm |   |
				| Hi,
 Can anyone tell me what is wrong with this .TRE file, .LST file, the 16F877 mcu does not work at all, but if I remove some code it starts to work, but than I am using only 26% memory.
 Also can anyone tell me if a function exceeds the segment size..
 ÀÄCLG004Main-v2
 ÃÄmain  1/105  Ram=0
 ³  ÃÄ??0??
 ³  ÃÄinitialise  0/45  Ram=0
 ³  ³  ÀÄinit_ext_eeprom  (Inline)  Ram=0
 ³  ÃÄload_settings  0/145  Ram=1
 ³  ³  ÃÄread_eeprom16byte  0/29  Ram=4
 ³  ³  ÀÄ@const10576  0/7  Ram=0
 ³  ÃÄcheck_mode  0/23  Ram=0
 ³  ÃÄcheck_selector  0/204  Ram=0
 ³  ³  ÀÄget_rotary_position  (Inline)  Ram=3
 ³  ³     ÀÄ@MUL88  0/39  Ram=2
 ³  ÃÄcheck_pushb  0/40  Ram=1
 ³  ³  ÀÄ@delay_ms1  0/23  Ram=1
 ³  ÃÄrelease_event  0/52  Ram=1
 ³  ³  ÃÄshow_cstep  (Inline)  Ram=1
 ³  ³  ³  ÀÄ@const10639  0/22  Ram=0
 ³  ³  ÀÄ@const10765  0/25  Ram=0
 ³  ÃÄpushb_event  0/151  Ram=1
 ³  ³  ÃÄselect_group  (Inline)  Ram=1
 ³  ³  ³  ÀÄ@const10654  0/19  Ram=0
 ³  ³  ÃÄ@const10739  0/19  Ram=0
 ³  ³  ÀÄshow_group  0/20  Ram=1
 ³  ³     ÀÄ@const10489  0/14  Ram=0
 ³  ÃÄzeroselect_event  0/54  Ram=1
 ³  ³  ÃÄshow_zero_err  (Inline)  Ram=1
 ³  ³  ³  ÀÄ@const10610  0/22  Ram=0
 ³  ³  ÀÄ@const10627  0/22  Ram=0
 ³  ÃÄselectorchange_event  0/29  Ram=1
 ³  ³  ÃÄ@const10713  0/26  Ram=0
 ³  ÀÄusart_rcvr  0/155  Ram=0
 ³     ÃÄget_command  (Inline)  Ram=2
 ³     ³  ÀÄ@const10516  0/11  Ram=0
 ³     ÀÄprocess_command  0/365  Ram=2
 ³        ÃÄ@goto10561  0/24  Ram=0
 ³        ÃÄwrite_ext_eeprom  (Inline)  Ram=6
 ³        ³  ÃÄ@I2C_WRITE_1_59_60_4000000  0/73  Ram=1
 ³        ³  ÀÄ@I2C_WRITE_1_59_60_4000000  0/73  Ram=1
 ³        ÀÄread_ext_eeprom  (Inline)  Ram=5
 ³           ÀÄ@I2C_READ_1_59_60_4000000  0/70  Ram=3
 ÃÄpc_usart_isr  0/10  Ram=0
 ÀÄperipheral_usart_isr  0/28  Ram=2
 ÃÄ@GETCH_3_  0/54  Ram=1
 ÃÄ@GETCH_4_  0/54  Ram=1
 ÀÄ@GETCH_2_  0/54  Ram=1
 The .LST file......
 CCS PCM C Compiler, Version 3.228, 16542               02-Aug-06 16:25
 Filename: CLG004Main-v2.LST
 ROM used: 2093 words (26%)
 Largest free fragment is 2048
 RAM used: 55 (31%) at main() level
 65 (37%) worst case
 Stack:    5 worst case (3 in main + 2 for interrupts)
 thanks
 arunb
		| treitmey
				|  Posted: Wed Aug 02, 2006 7:42 am |   |
		| arunb
				| RE: |
				|  Posted: Wed Aug 02, 2006 9:09 am |   |
				| Hi,
 PCM: 3.228
 MCU: 16F877A
 It compiles alright, with no errors, but does not work , while in target board.
 Well here is the code.
  	  | Code: |  	  |
 #include <16F877A.h>
 #priority RB,RDA
 #FUSES XT,NOWDT,PUT,NOPROTECT,NOCPD,BROWNOUT,NOLVP
 #define EEPROM_SDA  pin_c4
 #define EEPROM_SCL  pin_c3
 #define EEPROM_SIZE   0x7FF8
 #use rs232(baud=9600,xmit=pin_c6, rcv=pin_c7,parity=n,stream=PC)
 #use rs232(baud=1200,xmit=pin_d5, rcv=pin_b5,parity=n,stream=DISPLAY)
 #use rs232(baud=1200,xmit=pin_d7, rcv=pin_b3,parity=n,stream=RHSDRIVE)
 #use rs232(baud=1200,xmit=pin_d6, rcv=pin_b4,parity=n,stream=LHSDRIVE)
 #use i2c(master, sda=EEPROM_SDA, scl=EEPROM_SCL)
 #define PLC1 pin_e0
 #define PLC2 pin_e1
 #define PLC3 pin_e2
 #define R1P0 pin_a0
 #define R1P1 pin_a1
 #define R1P2 pin_a2
 #define R1P3 pin_a3
 #define R1P4 pin_a4
 #define R1P5 pin_a5
 #define R1P6 pin_c0
 #define R2P0 pin_c1
 #define R2P1 pin_c2
 #define R2P2 pin_d0
 #define R2P3 pin_d1
 #define R2P4 pin_d2
 #define R2P5 pin_d3
 #define R2P6 pin_c5
 #define PUSHB pin_b0
 #define MODE pin_b1
 #define VERSIONID "CLG004"
 //Event Register Settings
 //Bit 0   : Send command on controller start
 //Bit 1   : Pushbutton Enable
 //Bit 2   : Rotary Switch Change
 //Bit 3   : Mode Selector Change
 //Bit 4   : Checksum failed (for any peripheral)
 //Bit 5   : Checksum Passed (for all peripherals)
 //Bit 6   : PLC increment input receive
 //Bit 7   : PLC decrement input receive
 //Bit 8   : PLC reset input receive
 //Bit 9   : Start motion process
 //Bit 10   : End of motion
 //Bit 11   :
 //Bit 12   :
 //Bit 13   :
 //Bit 14   :
 //Bit 15   :
 //Bit 16   :
 #define EVENTREG 0x04
 #define WAITTIME 0x00
 #define PERIPHERAL 0x02
 #define MAXSTEPS 0xDF
 #define RECIPE 0x09
 #define TR0 0x0A
 #define TR1 0x0B
 #define TMPLOC 0x20
 #define TMPDATA 0x24
 int nDispRcv,nLHSRcv,nRHSRcv,nPeripheralRcv;
 char cRcvData,nUSARTCmd,nLocation,cDevice;
 int bPeripheralStatusFlg,bRcvFlg,bDisconnectFlg,bRPushbFlg,bPushbFlg,bGroupSelected;
 int val,nPLC,nStep,nMaxSteps,nGroup,nSide;
 int nSelector,nPrevMode,d0,d1,g0,g1,nPrevSelector;
 int16 nTmp1,nEventReg,nTmp2;
 int16 nWaitTime;
 int r1,r2;
 int bPushEvent,bReleaseEvent,bSelChangeEvent,bZSelectionEvent;
 int bRunModeEvent;
 int bProgramModeEvent,nMode,bShow,bWriteEEPROM,bReadEEPROM;
 void init_ext_eeprom()
 output_float(EEPROM_SCL);
 output_float(EEPROM_SDA);
 void write_ext_eeprom(long int address, BYTE data)
 short int status;
 i2c_start();
 i2c_write(0xa0);
 i2c_write(address>>8);
 i2c_write(address);
 i2c_write(data);
 i2c_stop();
 i2c_start();
 status=i2c_write(0xa0);
 while(status==1)
 i2c_start();
 BYTE read_ext_eeprom(long int address) {
 BYTE data;
 i2c_start();
 i2c_write(0xa0);
 i2c_write(address);
 i2c_start();
 i2c_write(0xa1);
 data=i2c_read(0);
 i2c_stop();
 return(data);
 void write_eeprom32byte(int nAddress,int32 nData)
 write_eeprom(nAddress,make8(nData,3));
 write_eeprom(nAddress+1,make8(nData,2));
 write_eeprom(nAddress+2,make8(nData,1));
 write_eeprom(nAddress+3,make8(nData,0));
 int32 read_eeprom32byte(int nAddress)
 int buffer1,buffer2,buffer3,buffer4;
 buffer1=read_eeprom(nAddress);
 buffer2=read_eeprom(nAddress+1);
 buffer3=read_eeprom(nAddress+2);
 buffer4=read_eeprom(nAddress+3);
 return(make32(buffer1,buffer2,buffer3,buffer4));
 void write_eeprom16byte(int nAddress,int16 nTData)
 write_eeprom(nAddress,make8(nTData,1));
 write_eeprom(nAddress+1,nTData);
 int16 read_eeprom16byte(int nAddress)
 int buffer1,buffer2;
 return(make16(buffer1,buffer2));
 void get_rotary_position1()
 r1=0;
 d0=0;
 d1=0;
 if (input(R1P0)==0)
 r1++;
 d0=0;
 if (input(R1P1)==0)
 r1++;
 d0=1;
 if (input(R1P2)==0)
 r1++;
 d0=2;
 if (input(R1P3)==0)
 r1++;
 d0=3;
 if (input(R1P4)==0)
 r1++;
 d0=4;
 if (input(R1P5)==0)
 r1++;
 d0=5;
 if (input(R1P6)==0)
 r1++;
 d0=6;
 if (input(R2P0)==0)
 r2++;
 d1=0;
 int get_rotary_position2()
 if (input(R2P1)==0)
 r2++;
 d1=1;
 if (input(R2P2)==0)
 r2++;
 d1=2;
 if (input(R2P3)==0)
 r2++;
 d1=3;
 if (input(R2P4)==0)
 r2++;
 d1=4;
 if (input(R2P5)==0)
 r2++;
 d1=5;
 if (input(R2P6)==0)
 r2++;
 d1=6;
 //delay_ms(50);
 return ((d1*0x0A)+d0);
 void check_selector()
 get_rotary_position1();
 nSelector=get_rotary_position2();
 nSelector=4;
 if (nSelector!=nPrevSelector)
 if (nSelector!=0)
 nPrevSelector=nSelector;
 bSelChangeEvent=1;
 bZSelectionEvent=1;
 void check_pushb()
 if (input(PUSHB)==0)
 if (bPushbFlg==0)
 bPushbFlg=1;
 bRPushbFlg=0;
 delay_ms(20);
 bPushEvent=1;
 bPushbFlg=0;
 if (bRPushbFlg==0)
 bRPushbFlg=1;
 bReleaseEvent=1;
 void check_mode()
 nMode=input(MODE);
 if (nMode!=nPrevMode)
 if (nMode==0)
 bRunModeEvent=1;
 bProgramModeEvent=1;
 nPrevMode=nMode;
 int16 get_step_data(int nTGroup ,int nTStep,int nSide)
 int16 nAddrs;
 int16 n;
 int nCntr;
 n=0xA6;
 for(nCntr=1;nCntr<nTGroup;nCntr++)
 n=n+0xA6;
 n=n-0xA6;
 switch (nSide)
 case 'R':   //Right Side
 nAddrs=((2*nTStep))+n+2+80;
 case 'L':   //Left Side
 nAddrs=((2*nTStep))+n+2;
 return(make16(read_ext_eeprom(nAddrs),read_ext_eeprom(nAddrs+1)));
 void save_step_data(int nTGroup ,int nSelStep,int16 nTDistance,int nDigSide)
 int16 nAddrs;
 int16 n;
 int nCntr;
 n=0xA6;
 n=n+0xA6;
 n=n-0xA6;
 switch (nDigSide)
 nAddrs=((2*nSelStep))+n+2+80;
 case 'L':
 nAddrs=((2*nSelStep))+n+2;
 write_ext_eeprom(nAddrs,make8(nTDistance,1));
 write_ext_eeprom(nAddrs+1,nTDistance);
 void waitfordevicercv(char cStream)
 int16 n;
 int bEndWaitFlg;
 bEndWaitFlg=0;
 n=0;
 do
 if (cStream=='D')
 if (bit_test(nPeripheralRcv,0)==1)
 bEndWaitFlg=1;
 if (cStream=='L')
 if (bit_test(nPeripheralRcv,1)==1)
 bEndWaitFlg=1;
 if (cStream=='R')
 if (bit_test(nPeripheralRcv,2)==1)
 bEndWaitFlg=1;
 delay_ms(1);
 n++;
 }while((n<nWaitTime)&&(bEndWaitFlg==0));
 int sendcommand(int nCommand,int bWait,int bRcv,char cStream)
 //nCommand   = The command (in 8 bit format)
 //bWait      = bWait-1 : Wait for acknowledge
 //            bWait-0 : Ignore acknowledge
 //bRcv      = The received data or acknowledge command
 //cStream   = The peripheral to which command is to be sent
 int h;
 enable_interrupts(INT_RB);
 enable_interrupts(GlOBAL);
 h=0;
 switch (cStream)
 case 'D':   //Display Module
 if (bit_test(bPeripheralStatusFlg,2)==1)
 bit_clear(nPeripheralRcv,0);
 val=fputc(nCommand,DISPLAY);
 h=1;
 case 'L':   //Left Side Drive Unit
 if (bit_test(bPeripheralStatusFlg,0)==1)
 bit_clear(nPeripheralRcv,1);
 val=fputc(nCommand,LHSDRIVE);
 h=1;
 case 'R':   //Right Side Drive Unit
 if (bit_test(bPeripheralStatusFlg,1)==1)
 bit_clear(nPeripheralRcv,2);
 val=fputc(nCommand,RHSDRIVE);
 h=1;
 if ((bWait==1)&&(h==1))
 waitfordevicercv(cStream);
 if ((bRcv==1)&&(h==1))
 return (nDispRcv);
 disable_interrupts(INT_RB);
 int read_device_eeprom(int nTLocation,char cDeviceCode)
 val=sendcommand('-',1,1,cDeviceCode);
 val=sendcommand(nTLocation,1,1,cDeviceCode);
 return (val);
 void write_device_eeprom(int nTLocation,int nEData,char cDeviceCode)
 val=sendcommand('+',1,1,cDeviceCode);
 val=sendcommand(nEData,1,1,cDeviceCode);
 int16 read_device_eeprom16Byte(int nTLocation,char cDeviceCode)
 int val2;
 val2=sendcommand(nTLocation+1,1,1,cDeviceCode);
 return (make16(val,val2));
 void write_device_eeprom16Byte(int nTLocation,int16 nData,char cDeviceCode)
 val=sendcommand(make8(nData,1),1,1,cDeviceCode);
 val=sendcommand(nTLocation+1,1,1,cDeviceCode);
 val=sendcommand(make8(nData,0),1,1,cDeviceCode);
 void uploadgroup(int nTGroup,char cDeviceCode,int nSide)
 int n1;
 int16 n;
 int nCntr;
 n=0xA6;
 n=n+0xA6;
 n=n-0xA6;
 nMaxSteps=read_ext_eeprom(n+1);
 if (cDeviceCode=='D')
 write_device_eeprom(0xB0,nMaxSteps,'D');
 for (n1=1;n1<=nMaxSteps;n1++)
 nTmp1=get_step_data(nTGroup ,n1,'L');
 write_device_eeprom16Byte((0x10+(n1*2)-2),nTmp1,'D');
 write_device_eeprom16Byte((0x60+(n1*2)-2),nTmp1,'D');
 if (n1==1)
 sendcommand('r',1,1,cDeviceCode);
 sendcommand('i',1,1,cDeviceCode);
 nTmp1=get_step_data(nTGroup ,n1,nSide);
 write_device_eeprom16Byte((n1*2)-2,nTmp1,cDeviceCode);
 write_device_eeprom(0x90,nMaxSteps,'D');
 void show_group()
 //   val=fputc('D',DISPLAY);
 //   val=fputc(0x0F,DISPLAY);
 val=fputc('N',DISPLAY);
 val=fputc(g0,DISPLAY);
 val=fputc(g1,DISPLAY);
 val=fputc(15,DISPLAY);
 val=fputc(0,DISPLAY);
 val=fputc(78,DISPLAY);
 val=fputc(79,DISPLAY);
 val=fputc(5,DISPLAY);
 val=fputc('R',DISPLAY);
 bShowGroup=0;
 puts("SHOW RECIPE",PC);
 int n,nStart,nEnd;
 nTmp2=0;
 switch (cDeviceCode)
 case 'L':      //Left Driver
 nStart=0;
 nEnd=read_device_eeprom(0x90,'L');
 case 'R':      //Right Driver
 nStart=0;
 nEnd=read_device_eeprom(0x90,'R');
 case 'D':      //Display Unit
 if (nSide=='L')
 nStart=0x10;
 nStart=0x60;
 nEnd=read_device_eeprom(0xB0,'D');
 for (n=1;n<nEnd>=0xFFFF)||(nWaitTime==0))
 nWaitTime=1000;
 nEventReg=make16(read_eeprom(EVENTREG),read_eeprom(EVENTREG+1));
 if (bit_test(nEventReg,0)==1)
 puts("CS");
 nGroup=read_eeprom(RECIPE);
 if (nGroup==0)
 write_eeprom(RECIPE,1);
 write_eeprom(TR0,1);
 write_eeprom(TR1,0);
 #ZERO_RAM
 void setup_ports()
 setup_adc(ADC_OFF );
 set_tris_a(0b11111111);
 set_tris_b(0b11111111);
 set_tris_d(0b00011111);
 set_tris_c(0b10111111);
 set_tris_e(0b11111111);
 init_ext_eeprom();
 output_float(pin_b4);
 output_float(pin_d6);
 output_float(pin_d5);
 output_float(pin_b5);
 output_float(pin_d7);
 output_float(pin_b3);
 void initialise()
 nGroup=1;
 g0=1;
 g1=0;
 enable_interrupts(INT_RDA);
 void usart_rcvr()
 bRcvFlg=0;
 if (nUSARTCmd==0)
 get_command1(cRcvData);
 get_command2(cRcvData);
 process_command1(cRcvData);
 process_command2(cRcvData);
 void show_zero_err()
 if (bShow==0)
 val=puts("ZERO RECIPE ERROR",PC);
 bShow=1;
 void zeroselect_event()
 if (bShow==0)
 show_zero_err();
 bShow=1;
 val=fputs("ZERO SELECT EVENT",PC);
 bZSelectionEvent=0;
 void show_cstep()
 val=fputs("SHOW CURRENT STEP",PC);
 void select_group()
 nGroup=nSelector;
 g0=d0;
 g1=d1;
 write_eeprom(RECIPE,nGroup);
 write_eeprom(TR0,g0);
 write_eeprom(TR1,g1);
 bGroupSelected=1;
 val=fputs("GROUP SELECTED",PC);
 void run_mode_event()
 val=fputs("RUN MODE EVENT",PC);
 bShow=0;
 if (nSelector!=0)
 //Upload Data to peripherals here.
 val=fputs("UPLOAD RECIPE",PC);
 //Show Error
 val=fputs("ZERO GROUP ERR",PC);
 show_zero_err();
 bRunModeEvent=0;
 void program_mode_event()
 val=fputs("PROGRAM MODE CHANGE EVENT",PC);
 bShow=0;
 bProgramModeEvent=0;
 void selectorchange_event()
 val=fputs("SELECTOR CHANGE EVENT",PC);
 if (nMode==0)
 show_group();
 bShow=0;
 bSelChangeEvent=0;
 bGroupSelected=0;
 void pushb_event()
 if (nSelector!=0)
 if (nMode==1)
 if (bGroupSelected==0)
 select_group();
 val=fputs("INCREMENT STEP");
 show_group();
 bShow=0;
 bPushEvent=0;
 void release_event()
 if (bShow==0)
 if (nMode==0)
 show_cstep();
 bShow=1;
 val=fputs("RELEASE BUTTON EVENT");
 bReleaseEvent=0;
 setup_ports();
 initialise();
 load_settings();
 //   waitfordevicercv('D');
 bPeripheralStatusFlg=0x07;
 do
 check_mode();
 check_selector();
 check_pushb();
 if (bReleaseEvent==1)
 release_event();
 if (bPushEvent==1)
 pushb_event();
 if (bZSelectionEvent==1)
 zeroselect_event();
 if (bSelChangeEvent==1)
 selectorchange_event();
 if (bRcvFlg==1)
 usart_rcvr();
 //   if (bWriteEEPROM==1)
 //      nTmp2=read_eeprom32byte(TMPLOC);
 //      nTmp1=read_eeprom16Byte(TMPDATA);
 //      write_ext_eeprom(nTmp2,nTmp1);
 //      val=fputc('A',PC);
 //   if (bReadEEPROM==1)
 //      nTmp1=read_ext_eeprom(nTmp2);
 //      val=fputc(nTmp1,PC);
 }while(TRUE);
 #int_rda
 void pc_usart_isr()
 cRcvData=getc();
 bRcvFlg=1;
 #int_rb
 void peripheral_usart_isr()
 int h;
 h=input_b();
 if (bit_test(h,3)==0)
 nRHSRcv=fgetc(RHSDRIVE);
 bit_set(nPeripheralRcv,2);
 if (bit_test(h,4)==0)
 nLHSRcv=fgetc(LHSDRIVE);
 bit_set(nPeripheralRcv,1);
 if (bit_test(h,5)==0)
 nDispRcv=fgetc(DISPLAY);
 bit_set(nPeripheralRcv,0);
 I removed the check_rotary functions and it started to work, removing the usart_rcvr also worked...
 thanks
 arunb
 | You cannot post new topics in this forum You cannot reply to topics in this forum
