how can I modify flex_lcd.c to drive NKK Smartswitch LCD
pdswar
PostPosted: Mon Jul 24, 2006 8:15 am     Reply with quote
I am a beginner to PIC programming and I am using PIC 18F6722 to drive NKK Smartswitch LCD.
http://www.nkksmartswitch.com/PDF/IS01NCF.pdf?
// As defined in the following structure the pin connection of Port F is as
// follows:
// F0 rs
// F1 rw
// F2 enable
// F3 LCD_LP
// F4 LCD_DOUT
// F5 LCD_BL
// Pins F6 and F7 are not connected
How can I modify flex_lcd.c to drive 36 X 24 pixel NKK Smartswitch LCD
Here is the link to flex_lcd.c
http://www.ccsinfo.com/forum/viewtopic.php?t=24661&postdays=0&postorder=asc&highlight=exexpio&start=0
PostPosted: Mon Jul 24, 2006 11:46 am     Reply with quote
The flex_lcd driver won't work with the NKK SmartSwitch. It's a
completely different type of display. They have a sample driver
here, written in Microchip ASM source code:
http://www.nkksmartswitch.com/agree.asp?url=pdf/PicSampleCode.pdf
Click the Download button to get it.
You'll have to convert it from ASM to C code. Please don't ask me
to do this for you.
Here are other resources:
Circuit Cellar articles:
http://www.circuitcellar.com/library/print/0702/kagan144/index.htm
http://www.circuitcellar.com/library/print/0802/kagan145/index.htm
Source code for the articles:
ftp://ftp.circuitcellar.com/pub/Circuit_Cellar/2002/145/kagan145.zip
PDF of the above articles:
http://www.nkksmartswitch.com/Uploads/DrivingSSPart1and2.pdf
Please do not ask me to translate the C code to CCS for you.
This is your project. You must do it.
pdswar
PostPosted: Wed Jul 26, 2006 1:35 pm     Reply with quote
PCM Programmer,
Thank you very much for the links.
