arunb
Kindly help with strange operation of 16F877A mcu |
Posted: Tue Aug 01, 2006 11:09 pm |
Can anyone tell me what is wrong with this .TRE file, .LST file, the 16F877 mcu does not work at all, but if I remove some code it starts to work, but than I am using only 26% memory.
Also can anyone tell me if a function exceeds the segment size..
ÀÄCLG004Main-v2
ÃÄmain 1/105 Ram=0
³ ÃÄ??0??
³ ÃÄinitialise 0/45 Ram=0
³ ³ ÀÄinit_ext_eeprom (Inline) Ram=0
³ ÃÄload_settings 0/145 Ram=1
³ ³ ÃÄread_eeprom16byte 0/29 Ram=4
³ ³ ÀÄ@const10576 0/7 Ram=0
³ ÃÄcheck_mode 0/23 Ram=0
³ ÃÄcheck_selector 0/204 Ram=0
³ ³ ÀÄget_rotary_position (Inline) Ram=3
³ ³ ÀÄ@MUL88 0/39 Ram=2
³ ÃÄcheck_pushb 0/40 Ram=1
³ ³ ÀÄ@delay_ms1 0/23 Ram=1
³ ÃÄrelease_event 0/52 Ram=1
³ ³ ÃÄshow_cstep (Inline) Ram=1
³ ³ ³ ÀÄ@const10639 0/22 Ram=0
³ ³ ÀÄ@const10765 0/25 Ram=0
³ ÃÄpushb_event 0/151 Ram=1
³ ³ ÃÄselect_group (Inline) Ram=1
³ ³ ³ ÀÄ@const10654 0/19 Ram=0
³ ³ ÃÄ@const10739 0/19 Ram=0
³ ³ ÀÄshow_group 0/20 Ram=1
³ ³ ÀÄ@const10489 0/14 Ram=0
³ ÃÄzeroselect_event 0/54 Ram=1
³ ³ ÃÄshow_zero_err (Inline) Ram=1
³ ³ ³ ÀÄ@const10610 0/22 Ram=0
³ ³ ÀÄ@const10627 0/22 Ram=0
³ ÃÄselectorchange_event 0/29 Ram=1
³ ³ ÃÄ@const10713 0/26 Ram=0
³ ÀÄusart_rcvr 0/155 Ram=0
³ ÃÄget_command (Inline) Ram=2
³ ³ ÀÄ@const10516 0/11 Ram=0
³ ÀÄprocess_command 0/365 Ram=2
³ ÃÄ@goto10561 0/24 Ram=0
³ ÃÄwrite_ext_eeprom (Inline) Ram=6
³ ³ ÃÄ@I2C_WRITE_1_59_60_4000000 0/73 Ram=1
³ ³ ÀÄ@I2C_WRITE_1_59_60_4000000 0/73 Ram=1
³ ÀÄread_ext_eeprom (Inline) Ram=5
³ ÀÄ@I2C_READ_1_59_60_4000000 0/70 Ram=3
ÃÄpc_usart_isr 0/10 Ram=0
ÀÄperipheral_usart_isr 0/28 Ram=2
ÃÄ@GETCH_3_ 0/54 Ram=1
ÃÄ@GETCH_4_ 0/54 Ram=1
ÀÄ@GETCH_2_ 0/54 Ram=1
The .LST file......
CCS PCM C Compiler, Version 3.228, 16542 02-Aug-06 16:25
Filename: CLG004Main-v2.LST
ROM used: 2093 words (26%)
Largest free fragment is 2048
RAM used: 55 (31%) at main() level
65 (37%) worst case
Stack: 5 worst case (3 in main + 2 for interrupts)
thanks
arunb |
treitmey
Posted: Wed Aug 02, 2006 7:42 am |
arunb
RE: |
Posted: Wed Aug 02, 2006 9:09 am |
PCM: 3.228
MCU: 16F877A
It compiles alright, with no errors, but does not work , while in target board.
Well here is the code.
#include <16F877A.h>
#priority RB,RDA
#FUSES XT,NOWDT,PUT,NOPROTECT,NOCPD,BROWNOUT,NOLVP
#define EEPROM_SDA pin_c4
#define EEPROM_SCL pin_c3
#define EEPROM_SIZE 0x7FF8
#use rs232(baud=9600,xmit=pin_c6, rcv=pin_c7,parity=n,stream=PC)
#use rs232(baud=1200,xmit=pin_d5, rcv=pin_b5,parity=n,stream=DISPLAY)
#use rs232(baud=1200,xmit=pin_d7, rcv=pin_b3,parity=n,stream=RHSDRIVE)
#use rs232(baud=1200,xmit=pin_d6, rcv=pin_b4,parity=n,stream=LHSDRIVE)
#use i2c(master, sda=EEPROM_SDA, scl=EEPROM_SCL)
#define PLC1 pin_e0
#define PLC2 pin_e1
#define PLC3 pin_e2
#define R1P0 pin_a0
#define R1P1 pin_a1
#define R1P2 pin_a2
#define R1P3 pin_a3
#define R1P4 pin_a4
#define R1P5 pin_a5
#define R1P6 pin_c0
#define R2P0 pin_c1
#define R2P1 pin_c2
#define R2P2 pin_d0
#define R2P3 pin_d1
#define R2P4 pin_d2
#define R2P5 pin_d3
#define R2P6 pin_c5
#define PUSHB pin_b0
#define MODE pin_b1
#define VERSIONID "CLG004"
//Event Register Settings
//Bit 0 : Send command on controller start
//Bit 1 : Pushbutton Enable
//Bit 2 : Rotary Switch Change
//Bit 3 : Mode Selector Change
//Bit 4 : Checksum failed (for any peripheral)
//Bit 5 : Checksum Passed (for all peripherals)
//Bit 6 : PLC increment input receive
//Bit 7 : PLC decrement input receive
//Bit 8 : PLC reset input receive
//Bit 9 : Start motion process
//Bit 10 : End of motion
//Bit 11 :
//Bit 12 :
//Bit 13 :
//Bit 14 :
//Bit 15 :
//Bit 16 :
#define EVENTREG 0x04
#define WAITTIME 0x00
#define PERIPHERAL 0x02
#define MAXSTEPS 0xDF
#define RECIPE 0x09
#define TR0 0x0A
#define TR1 0x0B
#define TMPLOC 0x20
#define TMPDATA 0x24
int nDispRcv,nLHSRcv,nRHSRcv,nPeripheralRcv;
char cRcvData,nUSARTCmd,nLocation,cDevice;
int bPeripheralStatusFlg,bRcvFlg,bDisconnectFlg,bRPushbFlg,bPushbFlg,bGroupSelected;
int val,nPLC,nStep,nMaxSteps,nGroup,nSide;
int nSelector,nPrevMode,d0,d1,g0,g1,nPrevSelector;
int16 nTmp1,nEventReg,nTmp2;
int16 nWaitTime;
int r1,r2;
int bPushEvent,bReleaseEvent,bSelChangeEvent,bZSelectionEvent;
int bRunModeEvent;
int bProgramModeEvent,nMode,bShow,bWriteEEPROM,bReadEEPROM;
void init_ext_eeprom()
output_float(EEPROM_SCL);
output_float(EEPROM_SDA);
void write_ext_eeprom(long int address, BYTE data)
short int status;
i2c_start();
i2c_write(0xa0);
i2c_write(address>>8);
i2c_write(address);
i2c_write(data);
i2c_stop();
i2c_start();
status=i2c_write(0xa0);
while(status==1)
i2c_start();
BYTE read_ext_eeprom(long int address) {
BYTE data;
i2c_start();
i2c_write(0xa0);
i2c_write(address);
i2c_start();
i2c_write(0xa1);
data=i2c_read(0);
i2c_stop();
return(data);
void write_eeprom32byte(int nAddress,int32 nData)
write_eeprom(nAddress,make8(nData,3));
write_eeprom(nAddress+1,make8(nData,2));
write_eeprom(nAddress+2,make8(nData,1));
write_eeprom(nAddress+3,make8(nData,0));
int32 read_eeprom32byte(int nAddress)
int buffer1,buffer2,buffer3,buffer4;
buffer1=read_eeprom(nAddress);
buffer2=read_eeprom(nAddress+1);
buffer3=read_eeprom(nAddress+2);
buffer4=read_eeprom(nAddress+3);
return(make32(buffer1,buffer2,buffer3,buffer4));
void write_eeprom16byte(int nAddress,int16 nTData)
write_eeprom(nAddress,make8(nTData,1));
write_eeprom(nAddress+1,nTData);
int16 read_eeprom16byte(int nAddress)
int buffer1,buffer2;
return(make16(buffer1,buffer2));
void get_rotary_position1()
r1=0;
d0=0;
d1=0;
if (input(R1P0)==0)
r1++;
d0=0;
if (input(R1P1)==0)
r1++;
d0=1;
if (input(R1P2)==0)
r1++;
d0=2;
if (input(R1P3)==0)
r1++;
d0=3;
if (input(R1P4)==0)
r1++;
d0=4;
if (input(R1P5)==0)
r1++;
d0=5;
if (input(R1P6)==0)
r1++;
d0=6;
if (input(R2P0)==0)
r2++;
d1=0;
int get_rotary_position2()
if (input(R2P1)==0)
r2++;
d1=1;
if (input(R2P2)==0)
r2++;
d1=2;
if (input(R2P3)==0)
r2++;
d1=3;
if (input(R2P4)==0)
r2++;
d1=4;
if (input(R2P5)==0)
r2++;
d1=5;
if (input(R2P6)==0)
r2++;
d1=6;
//delay_ms(50);
return ((d1*0x0A)+d0);
void check_selector()
get_rotary_position1();
nSelector=get_rotary_position2();
nSelector=4;
if (nSelector!=nPrevSelector)
if (nSelector!=0)
nPrevSelector=nSelector;
bSelChangeEvent=1;
bZSelectionEvent=1;
void check_pushb()
if (input(PUSHB)==0)
if (bPushbFlg==0)
bPushbFlg=1;
bRPushbFlg=0;
delay_ms(20);
bPushEvent=1;
bPushbFlg=0;
if (bRPushbFlg==0)
bRPushbFlg=1;
bReleaseEvent=1;
void check_mode()
nMode=input(MODE);
if (nMode!=nPrevMode)
if (nMode==0)
bRunModeEvent=1;
bProgramModeEvent=1;
nPrevMode=nMode;
int16 get_step_data(int nTGroup ,int nTStep,int nSide)
int16 nAddrs;
int16 n;
int nCntr;
n=0xA6;
for(nCntr=1;nCntr<nTGroup;nCntr++)
n=n+0xA6;
n=n-0xA6;
switch (nSide)
case 'R': //Right Side
nAddrs=((2*nTStep))+n+2+80;
case 'L': //Left Side
nAddrs=((2*nTStep))+n+2;
return(make16(read_ext_eeprom(nAddrs),read_ext_eeprom(nAddrs+1)));
void save_step_data(int nTGroup ,int nSelStep,int16 nTDistance,int nDigSide)
int16 nAddrs;
int16 n;
int nCntr;
n=0xA6;
n=n+0xA6;
n=n-0xA6;
switch (nDigSide)
nAddrs=((2*nSelStep))+n+2+80;
case 'L':
nAddrs=((2*nSelStep))+n+2;
write_ext_eeprom(nAddrs,make8(nTDistance,1));
write_ext_eeprom(nAddrs+1,nTDistance);
void waitfordevicercv(char cStream)
int16 n;
int bEndWaitFlg;
bEndWaitFlg=0;
n=0;
do
if (cStream=='D')
if (bit_test(nPeripheralRcv,0)==1)
bEndWaitFlg=1;
if (cStream=='L')
if (bit_test(nPeripheralRcv,1)==1)
bEndWaitFlg=1;
if (cStream=='R')
if (bit_test(nPeripheralRcv,2)==1)
bEndWaitFlg=1;
delay_ms(1);
n++;
}while((n<nWaitTime)&&(bEndWaitFlg==0));
int sendcommand(int nCommand,int bWait,int bRcv,char cStream)
//nCommand = The command (in 8 bit format)
//bWait = bWait-1 : Wait for acknowledge
// bWait-0 : Ignore acknowledge
//bRcv = The received data or acknowledge command
//cStream = The peripheral to which command is to be sent
int h;
enable_interrupts(INT_RB);
enable_interrupts(GlOBAL);
h=0;
switch (cStream)
case 'D': //Display Module
if (bit_test(bPeripheralStatusFlg,2)==1)
bit_clear(nPeripheralRcv,0);
val=fputc(nCommand,DISPLAY);
h=1;
case 'L': //Left Side Drive Unit
if (bit_test(bPeripheralStatusFlg,0)==1)
bit_clear(nPeripheralRcv,1);
val=fputc(nCommand,LHSDRIVE);
h=1;
case 'R': //Right Side Drive Unit
if (bit_test(bPeripheralStatusFlg,1)==1)
bit_clear(nPeripheralRcv,2);
val=fputc(nCommand,RHSDRIVE);
h=1;
if ((bWait==1)&&(h==1))
waitfordevicercv(cStream);
if ((bRcv==1)&&(h==1))
return (nDispRcv);
disable_interrupts(INT_RB);
int read_device_eeprom(int nTLocation,char cDeviceCode)
val=sendcommand('-',1,1,cDeviceCode);
val=sendcommand(nTLocation,1,1,cDeviceCode);
return (val);
void write_device_eeprom(int nTLocation,int nEData,char cDeviceCode)
val=sendcommand('+',1,1,cDeviceCode);
val=sendcommand(nEData,1,1,cDeviceCode);
int16 read_device_eeprom16Byte(int nTLocation,char cDeviceCode)
int val2;
val2=sendcommand(nTLocation+1,1,1,cDeviceCode);
return (make16(val,val2));
void write_device_eeprom16Byte(int nTLocation,int16 nData,char cDeviceCode)
val=sendcommand(make8(nData,1),1,1,cDeviceCode);
val=sendcommand(nTLocation+1,1,1,cDeviceCode);
val=sendcommand(make8(nData,0),1,1,cDeviceCode);
void uploadgroup(int nTGroup,char cDeviceCode,int nSide)
int n1;
int16 n;
int nCntr;
n=0xA6;
n=n+0xA6;
n=n-0xA6;
nMaxSteps=read_ext_eeprom(n+1);
if (cDeviceCode=='D')
write_device_eeprom(0xB0,nMaxSteps,'D');
for (n1=1;n1<=nMaxSteps;n1++)
nTmp1=get_step_data(nTGroup ,n1,'L');
write_device_eeprom16Byte((0x10+(n1*2)-2),nTmp1,'D');
write_device_eeprom16Byte((0x60+(n1*2)-2),nTmp1,'D');
if (n1==1)
sendcommand('r',1,1,cDeviceCode);
sendcommand('i',1,1,cDeviceCode);
nTmp1=get_step_data(nTGroup ,n1,nSide);
write_device_eeprom16Byte((n1*2)-2,nTmp1,cDeviceCode);
write_device_eeprom(0x90,nMaxSteps,'D');
void show_group()
// val=fputc('D',DISPLAY);
// val=fputc(0x0F,DISPLAY);
val=fputc('N',DISPLAY);
val=fputc(g0,DISPLAY);
val=fputc(g1,DISPLAY);
val=fputc(15,DISPLAY);
val=fputc(0,DISPLAY);
val=fputc(78,DISPLAY);
val=fputc(79,DISPLAY);
val=fputc(5,DISPLAY);
val=fputc('R',DISPLAY);
bShowGroup=0;
puts("SHOW RECIPE",PC);
int n,nStart,nEnd;
nTmp2=0;
switch (cDeviceCode)
case 'L': //Left Driver
nStart=0;
nEnd=read_device_eeprom(0x90,'L');
case 'R': //Right Driver
nStart=0;
nEnd=read_device_eeprom(0x90,'R');
case 'D': //Display Unit
if (nSide=='L')
nStart=0x10;
nStart=0x60;
nEnd=read_device_eeprom(0xB0,'D');
for (n=1;n<nEnd>=0xFFFF)||(nWaitTime==0))
nWaitTime=1000;
nEventReg=make16(read_eeprom(EVENTREG),read_eeprom(EVENTREG+1));
if (bit_test(nEventReg,0)==1)
puts("CS");
nGroup=read_eeprom(RECIPE);
if (nGroup==0)
write_eeprom(RECIPE,1);
write_eeprom(TR0,1);
write_eeprom(TR1,0);
#ZERO_RAM
void setup_ports()
setup_adc(ADC_OFF );
set_tris_a(0b11111111);
set_tris_b(0b11111111);
set_tris_d(0b00011111);
set_tris_c(0b10111111);
set_tris_e(0b11111111);
init_ext_eeprom();
output_float(pin_b4);
output_float(pin_d6);
output_float(pin_d5);
output_float(pin_b5);
output_float(pin_d7);
output_float(pin_b3);
void initialise()
nGroup=1;
g0=1;
g1=0;
enable_interrupts(INT_RDA);
void usart_rcvr()
bRcvFlg=0;
if (nUSARTCmd==0)
get_command1(cRcvData);
get_command2(cRcvData);
process_command1(cRcvData);
process_command2(cRcvData);
void show_zero_err()
if (bShow==0)
val=puts("ZERO RECIPE ERROR",PC);
bShow=1;
void zeroselect_event()
if (bShow==0)
show_zero_err();
bShow=1;
val=fputs("ZERO SELECT EVENT",PC);
bZSelectionEvent=0;
void show_cstep()
val=fputs("SHOW CURRENT STEP",PC);
void select_group()
nGroup=nSelector;
g0=d0;
g1=d1;
write_eeprom(RECIPE,nGroup);
write_eeprom(TR0,g0);
write_eeprom(TR1,g1);
bGroupSelected=1;
val=fputs("GROUP SELECTED",PC);
void run_mode_event()
val=fputs("RUN MODE EVENT",PC);
bShow=0;
if (nSelector!=0)
//Upload Data to peripherals here.
val=fputs("UPLOAD RECIPE",PC);
//Show Error
val=fputs("ZERO GROUP ERR",PC);
show_zero_err();
bRunModeEvent=0;
void program_mode_event()
val=fputs("PROGRAM MODE CHANGE EVENT",PC);
bShow=0;
bProgramModeEvent=0;
void selectorchange_event()
val=fputs("SELECTOR CHANGE EVENT",PC);
if (nMode==0)
show_group();
bShow=0;
bSelChangeEvent=0;
bGroupSelected=0;
void pushb_event()
if (nSelector!=0)
if (nMode==1)
if (bGroupSelected==0)
select_group();
val=fputs("INCREMENT STEP");
show_group();
bShow=0;
bPushEvent=0;
void release_event()
if (bShow==0)
if (nMode==0)
show_cstep();
bShow=1;
val=fputs("RELEASE BUTTON EVENT");
bReleaseEvent=0;
setup_ports();
initialise();
load_settings();
// waitfordevicercv('D');
bPeripheralStatusFlg=0x07;
do
check_mode();
check_selector();
check_pushb();
if (bReleaseEvent==1)
release_event();
if (bPushEvent==1)
pushb_event();
if (bZSelectionEvent==1)
zeroselect_event();
if (bSelChangeEvent==1)
selectorchange_event();
if (bRcvFlg==1)
usart_rcvr();
// if (bWriteEEPROM==1)
// nTmp2=read_eeprom32byte(TMPLOC);
// nTmp1=read_eeprom16Byte(TMPDATA);
// write_ext_eeprom(nTmp2,nTmp1);
// val=fputc('A',PC);
// if (bReadEEPROM==1)
// nTmp1=read_ext_eeprom(nTmp2);
// val=fputc(nTmp1,PC);
}while(TRUE);
#int_rda
void pc_usart_isr()
cRcvData=getc();
bRcvFlg=1;
#int_rb
void peripheral_usart_isr()
int h;
h=input_b();
if (bit_test(h,3)==0)
nRHSRcv=fgetc(RHSDRIVE);
bit_set(nPeripheralRcv,2);
if (bit_test(h,4)==0)
nLHSRcv=fgetc(LHSDRIVE);
bit_set(nPeripheralRcv,1);
if (bit_test(h,5)==0)
nDispRcv=fgetc(DISPLAY);
bit_set(nPeripheralRcv,0);
I removed the check_rotary functions and it started to work, removing the usart_rcvr also worked...
thanks
arunb |
