output_bit & delay question
javi.ar
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Mon Jul 24, 2006 3:08 pm     Reply with quote
Hi:
I have a question (newbie of course) regarding output_bit,
I need to place hex "words" bytes on a pin, this should be 1 = 50us high & 50us low and 0 = 100us high & 100us low.
Is the only chance to use the delay_us() command for keeping the port high & low in conjuntion with output_bit. I´ve tried with PWM and compare but I had no succeded (yet).
Thanks a lot.
Iam using 18f452 with 4MHZ XTAL and 8MHZ clock. but none of this is mandatory... just testing and learning, the goal is develop a dcc command / decoder for scale trains . Thanks a lot in advance as usual...
PostPosted: Mon Jul 24, 2006 5:00 pm     Reply with quote
Is the only chance to use the delay_us() command for keeping the port high & low ?
Look at the CCP and ECCP Tips 'n Tricks document from Microchip.
See Tip #8 for an idea of the general concept.
http://ww1.microchip.com/downloads/en/DeviceDoc/41214a.pdf
javi.ar
PostPosted: Mon Jul 24, 2006 5:36 pm     Reply with quote
Thanks a lot...
