changing format of __DATE__
mbge5amw
PostPosted: Wed Jul 19, 2006 3:26 am     Reply with quote
Is there a better way of doing this:
I wish to have a string containing the compile date in dd/mm/yy format.
I have written a very Heath Robinson routine that takes __DATE__ in its format 17-Jul-06 and changes it to 17/07/06 but this routine uses up valuable ROM and RAM.
Is there any way of getting this conversion to be performed automatically at compile time?
TIA
Andy
void generate_version( void )
  int8  local_date_t;
  int8  local_date_u;
  int8  local_month_t;
  int8  local_month_u;
  int8  local_year_t;
  int8  local_year_u;
  strcpy (motor_compile_date,__DATE__);
  local_date_t = motor_compile_date[0];
  local_date_u = motor_compile_date[1];
  local_year_t = motor_compile_date[7];
  local_year_u = motor_compile_date[8];
  switch(motor_compile_date[3])
    case 'J':
      switch(motor_compile_date[4])
        case 'a': //jan
          local_month_t = '0';
          local_month_u = '1';
        case 'u':
          switch(motor_compile_date[5])
            case 'n': //jun
              local_month_u = '6';
            case 'l': //jul
              local_month_u = '7';
    case 'F': // feb
      local_month_u = '2';
    case 'M':
        case 'a':
            case 'r': //mar
              local_month_u = '3';
            case 'y': //may
              local_month_u = '5';
    case 'A':
        case 'p': //apr
          local_month_u = '4';
        case 'u': //aug
          local_month_u = '8';
    case 'S': // sep
      local_month_u = '9';
    case 'O': // oct
      local_month_t = '1';
      local_month_u = '0';
    case 'N': // nov
    case 'D': // dec
  motor_version[0]='v';
  motor_version[1]='e';
  motor_version[2]='r';
  motor_version[3]=':';
  motor_version[4]=' ';
  motor_version[5] = ((local_date_t  & 0x0f) << 4) + (local_date_u  & 0x0f);
  motor_version[6] = ((local_month_t & 0x0f) << 4) + (local_month_u & 0x0f);
  motor_version[7] = ((local_year_t  & 0x0f) << 4) + (local_year_u  & 0x0f);
PostPosted: Wed Jul 19, 2006 6:26 am     Reply with quote
Unfortunately, I can't think of any truly 'better' way of doing this. The problem is that '__date__' is a pre-processor defintion, replaced as a constant string with the 'date'. All string comparisons/manipulations, are C operators, not preprocessor operators.
Personally, given that the 'date', is the compile date, and not something that should change in normal use, I'd do the following:
Firstly, just define your own constant at the start of the source, something like:
#define mdate 17/07/06
and make a point for now of changing this whenever you re-compile.
Then secondly, ask CCS, to consider generating a new '__numdate__' definition to the compiler, or a flag to switch the format of the 'date data'. This should be pretty easy for them to do, and could be of use to other people.
