What am I doing wrong with this syntax?
asmallri
PostPosted: Tue Jul 18, 2006 10:18 am     Reply with quote
With the following data structure
/* Directory object structure */
typedef struct _DIR {
   DWORD   sclust;      /* Start cluster */
   DWORD   clust;      /* Current cluster */
   DWORD   sect;      /* Current sector */
   WORD   index;      /* Current index */
} DIR;
If I have the following declaration:
FRESULT f_stat (
   char *path,   /* Pointer to the file path */
   FILINFO *finfo      /* Pointer to file information to return */
   FRESULT res;
   BYTE *dir;
   DIR dirscan;                  // <==== ERROR
   char fn[8+3+1]
The code fails compiling with a "Code has no effect" error.
However if I reorganize it like this it compiles ok
FRESULT f_stat (
   DIR dirscan;                  // <==== NO ERROR
   FRESULT res;
   BYTE *dir;
   char fn[8+3+1]
[/code]
Second problem
static
char make_dirfile (
   char **path,      /* Pointer to the file path pointer */
   char *dirname         /* Pointer to directory name buffer {Name(8), Ext(3), NT flag(1)} */
The compiler spits the dummy at char **path but does not mind the following:
typedef char* pchar;
pchar *path;
They should be equivalent.
Regards, Andrew
PostPosted: Tue Jul 18, 2006 11:48 am     Reply with quote
I can't do anything without a test program.
asmallri
PostPosted: Tue Jul 18, 2006 6:35 pm     Reply with quote
Thanks - I found the first one. I ported someone elses code to CCS and I didn't realise they have used case to differentiate labels. Such as DIR and dir
Regards, Andrew
