| View previous topic :: View next topic   |
			jecottrell
				| RS232 Pin to Monitor to Detect Connection |
				 Posted: Sat Jul 15, 2006 3:01 pm     |
				Hello All,
I'll be attempting a full 9 pin implementation of RS232 soon and would like to be able to have the PIC detect when a DTE is connected. What pin should I monitor to detect that event? The DTR?
Also, on the TTL/CMOS side of the level-shifter, what will be the logic levels when connected and unconnected?
Thanks,
John |
			jecottrell
				 Posted: Mon Jul 17, 2006 10:07 pm     |
				PCM,
Thanks. I hadn't seen that site before, even though I have Serial Port Complete.  I pulled that out and dusted it off and found alot of what I needed. (I had forgot it was in my book case.)
I went back to a simple 3 wire connection. Since it's for Small Burst Data (SBD), I shouldn't need any flow control and decided to keep it simple. However, I did rig up a Schottky w/ a series current limiting resistor and then a 3V zener to ground off the DTR line to the PIC to indicate when it's connected to the PC.
John |
