The uses of the __LINE__ operator
future
PostPosted: Mon Jul 17, 2006 11:16 am     Reply with quote
I am trying to run the protothread samples from:
http://www.sics.se/~adam/pt/
It uses the __LINE__ operator to set a variable like:
Long a;
a = __LINE__;
But the compiles does not expand it and generates an error about the unknown identifier.
Is this correct and it must be only used in defines and print?
PostPosted: Mon Jul 17, 2006 12:08 pm     Reply with quote
It works with PCM vs. 3.249. Here is the ASM code from the .LST
file for the program shown below.
0000            00302 ....... a = __LINE__;
000C 1283       00303 BCF    03.5   // Bank 0
000D 01A2       00304 CLRF   22    // MSB = 0
000E 300A       00305 MOVLW  0A
000F 00A1       00306 MOVWF  21   // LSB = 0x0A  (line 10)
#include <16F877.h>
main()
Long a;
a = __LINE__;
