newbie need help with if statement
sheing3003
PostPosted: Wed Jul 05, 2006 4:41 pm     Reply with quote
ok i want to do something like this, but obviously this does not work like c, so if someone can help me out and give me a good example that'll be great
this is what i wanted to do, but the #if only evaluate to a constant or something.... can someone help me change my code so it'll do the same thing? Thanks in advance
#include <16F877A>
#fuses HS
#fuses NOWDT
#fuses NOPROTECT
#fuses NOLVP
#fuses NODEBUG
#fuses PUT
#fuses NOBROWNOUT
int8 a;
a=100;
output_c(0);
output_bit(PIN_C0,1);
output_bit(PIN_C1,1);
output_bit(PIN_C2,1);
output_bit(PIN_C3,1);
#if a>90
output_bit(PIN_C0,0);
#elif a>70
output_bit(PIN_C1,0);
#elif a>50
output_bit(PIN_C2,0);
#elif a>30
output_bit(PIN_C3,0);
#else
a=100;
#endif
a--
PostPosted: Wed Jul 05, 2006 4:56 pm     Reply with quote
Please read these tutorials on the if-else statement in the C language.
http://cslibrary.stanford.edu/101/EssentialC.pdf
(see page 11)
http://www.its.strath.ac.uk/courses/c/subsection3_8_1.html
sheing3003
PostPosted: Wed Jul 05, 2006 5:03 pm     Reply with quote
(see page 11)
ok never mind....
i thought you cant use if statement... that's why i use #if...
wow~~ this is amazing! lol
