i want to run the usb firmware for pic16c745 which is written in assembler in my c file
my problem is, that i can't implement the firmware in the c code because ccs only allows inline assembly and the firmware runs include files with macros.
how can i compile my c file into assembler and link it with the firmware?????
thx for help
___________________________
Original Post ID: 12520
Re: link an assembler file with an c file
Posted: Tue Mar 11, 2003 3:11 pm
:=i want to run the usb firmware for pic16c745 which is written in assembler in my c file
:=my problem is, that i can't implement the firmware in the c code because ccs only allows inline assembly and the firmware runs include files with macros.
:=how can i compile my c file into assembler and link it with the firmware?????
There is no separate linker with the CCS compiler.
You can't make linkable object modules.
Can you post a link to the ASM source code for the firmware ?
Maybe we can look at it, and give you some suggestions on
how integrate it into your C source code.
Original Post ID: 12542
