fix tris i/o bits
fvnktion
fix tris i/o bits
PostPosted: Wed Jul 05, 2006 2:07 pm     Reply with quote
Im sure this is a newb question, but i have not been able to find an answer by searching the reference manual or forums.
Im am trying to fix an0 and an1 on 16f88 as inputs. I am trying to use the rest of porta pins (2-7) as outputs or inputs. I need to be able to use the set_port_x() without affecting an0 and an1. I need output pins on porta to change simultaneously, as they are switching inputs on a toggled motor control driver.
Is there a command that will fix these the an0,1 ports and not affect them when using the set_port_x() function??
Thank you for your help!
PostPosted: Wed Jul 05, 2006 2:29 pm     Reply with quote
You could use the #use fixed_io() statement, and specify which
pins on Port A are to be used as outputs. All remaining pins on
Port A are then considered to be inputs by the compiler.
#include <16F88>
#use delay(clock = 4000000)
#use fixed_io(A_outputs = PIN_A2, PIN_A3, PIN_A4)
int8 status_0;
int8 status_1;
output_a(0x00);
delay_us(50);
output_a(0xFF);
status_0 = input(PIN_A0);
status_1 = input(PIN_A1);
This answer assumes that all pins are digital i/o.
Also be aware that pin RA5 is an input-only pin on the 16F88.
fvnktion
PostPosted: Wed Jul 05, 2006 3:04 pm     Reply with quote
Thanks for the reply.
I am not sure if this will be conflicting using the ADC, as they will be used as analog inputs rather than digital inputs?? Does the fix_io function take this into account?
essentially what i am trying to do is this:
#include <16F88>
#device ADC=10
#use delay(clock=8000000)
#fuses INTRC_IO,NOWDT,NOMCLR,NOPROTECT,NOCPD,NOBROWNOUT,NOLVP//INTRC_IO //nolvp for lcd
//#use fixed_io(a_outputs=PIN_A0, PIN_A1)
void main() {
long int Tvalue,tilt;
//setup adc values
setup_oscillator(OSC_8MHZ);//sets internal osc multiplier
SETUP_ADC_PORTS(sAN0 | VSS_VDD);
SETUP_ADC(ADC_CLOCK_DIV_32);
while(1){
//read adc value
Tvalue = READ_ADC(ADC_START_AND_READ);
//adc tilt value eval
if (Tvalue>1015)
tilt = 0b00000100; //Tiltdown
else if (Tvalue>991)
tilt = 0b00011000;//tiltup
else if (Tvalue>950)
tilt = 0b00001100; //0b07;//tiltLeft
else if (Tvalue>915)
tilt = 0b00010000; //0b0001111;tiltRight
tilt = 0; //0;
OUTPUT_A(tilt);
reads portan0, evaluates state, outputs on porta, not using pina0,pina1.
Is there an easier or better approach to using port a as input/output simultaneously with Analog inputs and the ADC??
Thank you for the help!
PostPosted: Wed Jul 05, 2006 4:34 pm     Reply with quote
You need to make the changes shown in bold below.
#include <16F88>
#device adc=10
// Select pins on Port A which will be used for output only.
// All unspecified pins on Port A will be input-only pins.
// Note that on the 16F88, PIN_A5 is an input only pin.
// It can't ever be an output pin.
long int Tvalue, tilt;
setup_adc_ports(sAN0 | VSS_VDD);
setup_adc(ADC_CLOCK_DIV_16); // Use DIV_16 for 8 MHz
set_adc_channel(0); // Must select ADC channel 0
Tvalue = read_adc(); // Default mode is to read ADC
if(Tvalue > 1015)
tilt = 0b00000100; // Tiltdown
else if(Tvalue > 991)
tilt = 0b00011000; // tiltup
else if (Tvalue > 950)
tilt = 0;
output_a(tilt);
