PIN NOT TOGGLING
pasini
PIN NOT TOGGLING
PostPosted: Tue Jul 04, 2006 8:51 am     Reply with quote
MPLB 7.10 CCS 3.324
Hi I have the following code but pin D5 is not toggling. I donŽt know why.
Can anyone help me ?
Pasini
#define __USB_PIC_PERIF__ 1
#include <18F4550.h>
#device *=16
#device ADC=10
//configure a 16MHz crystal to operate at 48MHz
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,CPUDIV1,VREGEN,PLL4
#use delay(clock=48000000)
#case
#define USB_CON_SENSE_PIN PIN_C6
#include <defines.h>
#byte PORTE = 0x0F84
int8 data;
   set_tris_a(0b00100001);      // bits 6 e 7 ?
   set_tris_b(0b11010001);
   set_tris_c(0b01111100);
   set_tris_d(0b01011000);
   set_tris_e(0b00000111);
   setup_psp(PSP_DISABLED);
   setup_ccp1(CCP_OFF);
   setup_adc_ports(NO_ANALOGS);
   {   output_high(PIN_D5);
      output_high(PIN_B3);
      output_low(PIN_D7);
      output_low(PIN_B3);
PostPosted: Tue Jul 04, 2006 9:08 am     Reply with quote
Why should it toggle?...
You only ever set it high.
pasini
PostPosted: Tue Jul 04, 2006 8:15 pm     Reply with quote
IŽll talk to my boss I need 2 weeks at the beach far from my computer.
Thanks anyway !!!!!!!!
Pasini
PostPosted: Wed Jul 05, 2006 2:03 am     Reply with quote
I know the feeling all too well...
Especially in the UK at the moment, with a 'heatwave'.
Storic
PostPosted: Wed Jul 05, 2006 6:07 am     Reply with quote
You have a heat wave Shocked
not to many brass monkeys down south in Australia Sad
Andrew Wink
What has been learnt if you make the same mistake? Wink
PostPosted: Wed Jul 05, 2006 6:44 am     Reply with quote
Yes. Amazing I know, but had two new 'record high' temperatures in June, and another already in July. 33C here at the moment (91F), not quite so hot as yesterday, and thunderstorms nearby. As always, seems hotter, because our architecture in particular is not designed to 'help' in hot weather. Definately the sort of temperatures that make 'not thinking about computers', seem a very nice idea...
