john.whung Guest
i have a timer0 calculate Q? |
Posted: Tue Jun 27, 2006 4:30 am |
#if defined(__PCM__)
#include <16F877.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) // Jumpers: 8 to 11, 7 to 12
#elif defined(__PCH__)
#include <18F452.h>
#define INTS_PER_SECOND 76 // (20000000/(4*256*256))
BYTE seconds; // A running seconds counter
BYTE int_count; // Number of interrupts left before a second has elapsed
#int_rtcc // This function is called every time
void clock_isr() { // the RTCC (timer0) overflows (255->0).
// For this program this is apx 76 times
if(--int_count==0) { // per second.
++seconds;
int_count=INTS_PER_SECOND;
BYTE start;
set_timer0(0);
setup_counters( RTCC_INTERNAL, RTCC_DIV_256 | RTCC_8_BIT);
enable_interrupts(INT_RTCC);
do {
printf("Press any key to begin.\n\r");
getc();
start=seconds;
printf("Press any key to stop.\n\r");
getc();
printf("%u seconds.\n\r",seconds-start);
} while (TRUE);
this code is a compiler's example.
What does it mean this expression: set_timer0(0); ?
Thanks |
sjbaxter
Joined: 26 Jan 2006 Posts: 141 Location: Cheshire, UK
Posted: Tue Jun 27, 2006 5:08 am |
It means exactly what is says .... set timer0 to a value of zero !!!
Try reading the CCS C Compiler help manual. _________________ Regards,
Simon. |
pin62426
WHY? |
Posted: Thu Jun 29, 2006 5:59 am |
THE code
What does it mean this expression ?
specifically, the "RTCC_DIV_256 | RTCC_8_BIT" mean?
how can i application code equation? |
Humberto
