lerastas
pic stop when read RS232 ??? |
Posted: Tue Jun 27, 2006 12:36 pm |
Hello everybody, I would like if you know why my pic 16F876A stop the read of RS232.
In fact, the pic read the data but stop when it want!!! I don't know why. Is it because the GPS data doesn't send the data every time. But my code wait a $ before continue.
It's the GPGGA data.
If anyone can reply, it will be cool!!
Thanks, sorry for the English!!
Lerastas
#include <16F876A.h>
#use rs232(baud=38400,xmit=PIN_C6,rcv=PIN_C7, stream=GPS)
#include <string.h>
#include <stdlib.h>
char k;
char i;
char string[6];
char buffer[45];
char compar[]="GPGGA,";
char heure[3], minutes[3], sec[3], ms[3], sat[3], trame[6];
void read_GPS ()
while ( fgetc(GPS) != 36 ); // wait a $
for (k=0;k<45;k++) buffer[k]=fgetc(GPS);
while (strncmp(buffer,compar,6)!=0);
for (i=0; i<2; i++)
heure[i]=buffer[i+6];
heure[2] = '\0';
for (i=0; i<2; i++)
minutes[i]=buffer[i+8];
minutes[2] = '\0';
for (i=0; i<2; i++)
sec[i]=buffer[i+10];
sec[2] = '\0';
for (i=0; i<2; i++)
ms[i]=buffer[i+13];
ms[2] = '\0';
for (i=0; i<2; i++)
sat[i]=buffer[i+43];
sat[2] = '\0';
heure_bis=atoi(heure);
minutes_bis=atoi(minutes);
sec_bis=atoi(sec);
ms_bis=atol(ms)*10;
sat_bis=atol(sat);
init();
read_GPS(); //lecture de la trame GPS
fprintf(GPS,"donnees GPS %u heure %u minutes %u sec %u nb sat %ld ms\n\r", heure_bis,minutes_bis ,sec_bis, sat_bis,ms_bis);
Posted: Tue Jun 27, 2006 12:47 pm |
The UART receiver may be locking up. When you do the large fprintf()
statement, you are not checking the UART for incoming characters.
If the hardware fifo fills up (it can only hold 2 characters) and you
receive one more character, then the UART receiver will lock up.
You can make the compiler add code to automatically clear the lock-up
by adding the ERRORS parameter as shown in bold below.
Quote: | #use rs232(baud=38400,xmit=PIN_C6,rcv=PIN_C7, ERRORS, stream=GPS) |
It would be better if you prevent the lockup completely by adding
an interrupt-driven software receive fifo, as shown in the CCS example
file, EX_SISR.C. Look in this folder for it:
c:\Program Files\PICC\Examples |
