prayami
EEPROM reading 0 on starting |
Posted: Mon Jun 26, 2006 11:13 pm |
Hi...I made a simple following program. Sometime on starting it is
reading eeprom value 0.
Even though I increase or descrase sometime it is reading perfect
after power on but sometime it is reading 0 even though it was greater
than 0 while running normal.
I tried to display the ScrPercent variable on 7-segment LED.
I am using 18F4525, CCS PCH C Compiler, Version 3.249 and
10MHz crystal X PLL = 40MHz.
Anybody have any idea why it is doing like that?
Is it require any delay before and after reading eeprom and writing eeprom?
#include <18F4525.h>
#fuses H4,NOWDT,NOLVP,BROWNOUT,BORV46,NOPBADEN,PUT,NOXINST,NOMCLR,NOLPT1OSC,NOWRT,NOWRTD,EBTR,NOCPB,EBTRB,NOWRTC,
NOWRTB,PROTECT,CPD,CCP2B3
#use delay(clock=40000000)
#define DOWN_BUTTON PIN_B1
#define UP_BUTTON PIN_B5
#define SCRAM_PERCENT 0x0A
unsigned int8 ScrPercent=0;
set_tris_a(0xFF);
set_tris_c(0x00);
set_tris_d(0x00); // We need only Port D as output
set_tris_b(0xFF); //check this
delay_ms(10);
ScrPercent = read_eeprom(SCRAM_PERCENT);
while(TRUE) {
if(ScrPercent == 0)
output_high(PIN_D4);
output_low(PIN_D4);
if(!input(UP_BUTTON))
delay_ms(300);
if(ScrPercent<100)
ScrPercent++;
else if(ScrPercent>100)
ScrPercent = 1;
else if(!input(DOWN_BUTTON))
delay_ms(300);
if(ScrPercent>0)
ScrPercent--;
}//if(!input(UP_BUTTON))
write_eeprom(SCRAM_PERCENT, ScrPercent);
//sprintf(int_str,"%3U",ScrPercent);
//DisplayInt(int_str[0], int_str[1], int_str[2]);
}//while(TRUE)
}//main
Posted: Tue Jun 27, 2006 4:00 am |
At heart, what you post should work, _but_ will kill the EEPROM in only a few minutes!...
As posted, the code sits writing the EEPROM, on every loop. There are no delays in the loop, if no buttons are pressed, so the loop 'time' will be a total of just on 4mSec/loop. This gives about 250 writes/second. The write endurance of the EEPROM, has a 'worst case' spec of only 100K cycles, so the chip could die in about 400 seconds. Even if the chip is better than this, and meets the 'typical' spec of 1M cycles on the EEPROM, this only rises to 4000 seconds. So anything between about 7 minutes, and an hour of this code, will kill the EEPROM...
I suspect this is what you have done.
Key is:
Only write the EEPROM if the value _has_ changed...
prayami
Posted: Tue Jun 27, 2006 3:29 pm |
Thanks....Ttelmah....you told very important thing....
I read from the previous post that: before writting eeprom, read it first
and check whether the value has changed or not. If changed then
only write and thus increasing the eeprom life. One question I have is
does those 100K cycle life also consider the eeprom reading? Means
if you read the eeprom number of times say more than 100K cycles than
also eeprom can dead..??
Is it require any delay before or after writting and reading EEPROM?.
Because of which it is reading 0 sometime.....
Thanks..... |
