Some very Basic Questions About External Memory
deltatech
PostPosted: Sun Jun 25, 2006 10:54 am     Reply with quote
Some very basic questions about memory from a fairly newbie so please respond kindly. !
1 what is the difference between EEPROM (9536) and SRAM (PCFF8570) ?
2 Where would you use either .
3 Both memory capacity is 256 , what if I need more memory ? .
I have used CCS example EX_EXTEE.C and EX_SRAM . They work fine.
4 But they only ask for a Two digit address . So I if I want to address more memory how do I adopt these examples to read more address.
5 I want to read the following table in to either external memory . can this be done . ? Ie is there enough memory to accommodate this table .
6 How do I calculate how much memory I need . ? For example for the table below how do I work out how much memory this table needs .
7 If I wanted to write the following Table in say PCFF870 how would I do that ? because CCS WRITE_EXT_SRAM( address, value );andREAD_EXT_SRAM( address )only write and read one address at a time .
8 The other thing I have noticed is If I write TT and read it back its no longer TT but FF . So how do I save alpha characters ABCDEFGH etc .
As you can I am new to memory this is the first time I have connected memory on breadboard with a PIC and I am still learning .
Many Thanks In Advance ..
1 12   239   539   139   639   939   439   739   839
2 12   339   639   239   739   1039   539   839   939
3 12   439   739   339   839   1139   639   939   1039
4 12   539   839   439   939   1239   739   1039   1139
5 12   639   939   539   1039   1339   839   1139   1239
6 12   739   1039   639   1139   1439   939   1239   1339
7 12   839   1139   739   1239   1539   1039   1339   1439
8 12   939   1239   839   1339   1639   1139   1439   1539
9 12   1039   1339   939   1439   1739   1239   1539   1639
10 12   1139   1439   1039   1539   1839   1339   1639   1739
11 12   1239   1539   1139   1639   1939   1439   1739   1839
12 12   1339   1639   1239   1739   2039   1539   1839   1939
13 12   1439   1739   1339   1839   2139   1639   1939   2039
14 12   1539   1839   1439   1939   2239   1739   2039   2139
15 12   1639   1939   1539   2039   2339   1839   2139   2239
16 12   1739   2039   1639   2139   039   1939   2239   2339
17 12   1839   2139   1739   2239   139   2039   2339   039
18 12   1939   2239   1839   2339   239   2139   039   139
19 12   2039   2339   1939   039   339   2239   139   239
20 12   2139   039   2039   139   439   2339   239   339
21 12   2239   139   2139   239   539   039   339   439
22 12   2339   239   2239   339   639   139   439   539
23 12   039   339   2339   439   739   239   539   639
24 12   139   439   039   539   839   339   639   739
25 12   239   539   139   639   939   439   739   839
26 12   339   639   239   739   1039   539   839   939
27 12   439   739   339   839   1139   639   939   1039
28 12   539   839   439   939   1239   739   1039   1139
29 12   639   939   539   1039   1339   839   1139   1239
30 12   739   1039   639   1139   1439   939   1239   1339
31 12    839   1139   739   1239   1539   1039   1339   1439
asmallri
PostPosted: Sun Jun 25, 2006 7:58 pm     Reply with quote
It is not a good idea post in bold face it make it difficult to read. Generally bold should only be used to emphasise a specific point.
EEPROM = Electrically Eraseable Read Only Memory. Once you wite to it, information is retained through power cycling - depending on the device it can retain the information for up to 100 years. It takes typically 5 to 20ms to write either a single byte or a page depending on the device. You could use higher capacity EEPROMs. Microchip has a 512K bit (64K byte) version 24LC512
SRAM - Static RAM. Data is lost in the event of power loss. Write access is very fast (no 5 to 20ms write delay). SRAMs are rather limited in capacity compared to EEPROM sizes. However there is an alternative. A FRAM such as the RAMTRON 24C256 is a 256K bit (32K byte) device that has the access speed of RAM but is non volatile - retains program through power cycle.
Regards, Andrew
PostPosted: Mon Jun 26, 2006 1:43 am     Reply with quote
You are asking a lot of questions, many of them so easy to answer that I'm wondering if you have even tried to look up the answer yourself.
Looking at the questions you are asking I'm wondering why you are comming up with these specific part numbers. What made you decide to use external memory? Save yourself (and us) a lot of time by buying a PIC with more internal memory.
